1994 audi cabriolet convertible (top won't let down)
#21
#22
Trunk wiring in my book, and specifically the wiring associated with the trunk lock. The convertible top control module must sense that the trunk is locked for the top cover to fully open. This prevents the top storage compartment cover and the trunk from hitting each other. Look at my earlier PDF's I posted for the sequence. Here's a quick test. Key lock the trunk and then try to operate the top. Sometimes that will work and show you that the problem is clearly the trunk lock. Next, try using the key to lock the doors and open them and try the top again. I'm not sure what sensors Loud is referring to, unless he means the three latch sensors on each side in the top storage compartment that are microswitches. I don't think he is implying that they are optical.
#23
Actually Hub, I was implying they're optical.
They're also mounted as a safety feature on a completely different car...
Have Iever told you about the '95 Saab 900S convertible I used to own? Nice little car. Had these cool little optical sensors for a safety feature. Kept you from losing a finger if your hand was resting in the wrong place.
Sorry, Grease.
I'll fire up the ElsaWin, though. Lets see what we can find... I'll be back in a few.
Nothing. There are no wiring diagrams for the hydraulic top system in this program.
Sorry, Grease.
#24
It's working again, thanks to evryone. after reading LG's reply I went to my car and unlock it in the trunk. I opened my trunk and tried to bang the back of the boot cover. Closed the trunk and went to start it and unlatch the top and lo and behold it's working again. put it up and down for four times and no problem. Now it's time to enjoy the weather. Thank you to all.
cheers
greasegun
cheers
greasegun
#27
How to answer this one?
Tedero,
If I was 25 and you were a great looking babe, I'd call you. Since that is not going to happen, search the forum and read everything you can on the convertible top. You need to learn a few things so that you can aptly describe what is happening, such as if the light is blinking, where in the sequence you get the failure, etc. We will all tell you the same thing. It is most likely the trunk lock or the trunk lock wiring.
#28
This is a hydraulic system. Slow running in a hydraulic system can usually be attributed to one of two things:
1) Low fluid, allowing air bubbles to get in to the hydraulic lines. Fluid cannot compress under pressure. Air can.
2) The motor used to pressurize the system is failing. Much less likely.
The tank holding the hydraulic fluid is in the trunk near the passenger side rear corner, under the black carpet floor. The fluid used to top it off is the same fluid used as power steering fluid in our cars. It is sold at Audi dealerships.
#29
Pump motor
Since Loud brought it up, I did have a problem in my pump motor. When you check your fluid level, which really should be your first step in the elimination process, do it after you have operated the top. You'll need a flashlight and mirror. This way you will be able to smell if the motor brushes or motor are shorting out. In my case, the brush material (a carbon graphite like material) was imbedded in the armature comutator gaps. This caused the motor to intermittantly short out and stop in mid opening. I removed the hydraulic assembly, separated the motor from the pump, opened up the electric pump motor and cleaned out the material from the grooves in the comutator and reassembled. The brushes are not easily replaceable, unfortunately, and the motor itself is not stocked as a separate part. Audi sells the whole hydraulic assembly for $2400. Total Rip-off.
