20v Not getting spark on all cylinders
I have a 91 audi 90 20v 7a and one day she wouldn't start. I checked to see if I was getting spark and was not on #2 and #4. I checked to make sure the hall sensor was getting the correct power and it was. I tried a different distributor and still no changed. I swapped the ecu from my parts car and now I get spark on #4 but still nothing on #2. So Im assuming my ecu is shot? Whats my next step? Is there anything I can check before I try to find a new ecu?
I don't know the numbers but you can check the resistance of the wires. Or switch wires around and see if the fault follows the wires. If its getting colder where you are, older wires with faults will get "faultier"
Doug
Doug
Ive swapped wires and test straight from the cap. No change. Its cold here now and nothing has changed.
You have to check the voltage or power at the back of ECM that you need to do I think. Good luck and Happy Holidays. x19
Ps, What is your ECM # ? I may have.
bd__14
09-23-2012 03:42 AM
Snow Trooper *Swiss*
9
09-25-2006 09:17 PM
90mtl
09-16-2006 03:50 PM
jurq
05-04-2006 05:44 AM
