Failed Emission Test
The culprit is high CO, Carbon Monoxide, or partially / un-burned fuel. During the yearlong down time I had all the injector seals replaced as well as the distributor... plus a bunch of other non ignition related items. It idles well and seems to drive fine, but does seem to knock under low RPM hard acceleration. Since it has never failed a smog check the last 20+ years I can't help but assume that something related to the recent work has changed the emissions output. Oh, and the air filter is new, so probably not the problem.
As I have absolutely no idea I was hoping someone here may have experienced a similar problem.
You will see the swinging the voltage on DVOM (your case is probably high 0.8~0.4 or stays at more than 0.6v, I hope that wasn't). Adjust to swing to 0.2~0.9 voltage (screw out or in) is just wright point and you will see the water coming out from exhaust tail pipe. Make sure,clean the spark plugs too.
Good luck. x19
I'm having the same emissions test failure right now. Hydrocarbons are in the 1.4k range and CO is 1.5. A previous owner of this car used zip ties on most of the intake hoses (which I replaced with clamps) and I thought I solved the leaks, but there must be something leaking still.
And you have to correct HC problem first then CO can be adjust by 3 mm allen wrench (see my post #4 above. Good luck. x19
As to the mechanic, I have been taking this to Rick at Save-On Tires in Tigard for a while now as he is an Audi/VW factory trained master mechanic (that's where the car is now)
For the other items on the punch list...
Cam = running a TechTonics 268 Hydro for ten years and has passed emissions every time with no problems.
Injectors = had all the injectors pulled and put new seals on this summer
Compression = tested good on all cylinders
Distributor = replaced about 4 months ago (I still think this may be where the problem lies)
Vacuum Hose = mechanic did a smoke test a few months back and all looked good
I (or a mechanic) will take these suggestion in hand and keep looking for the solution.
Hi, did you test the spray pattern from injectors when you removed them?
this is better idea to see the spray pattern and some time aim of spray was off center and not mist enough or may be too much fuel spray etc.
Here is how to test.
Remove the intake boot on fuel distributor and injector on to plastic pan.
Remove Fuel pump Relay and by passe the power to operate fuel pump without start Engine ( Don't do this ! and any spark or include safety match)
If you bypass power correctly,you will hear buzzer sound from F/distributor and now you have to lift or push down float valve. you will see the condition of spray how they spray like the making mist or dropping fuel or etc.
Even you see the good pattern, you can clean all injector to make the full throttle condition few times and remove(clean) the dirty on float valve then put back all injector to engine.
Reset the fuel mixture by adjusting 3 mm allen wrench screw( see previous my post).
Good luck and Happy Holidays. x19
