'95 90 Quattro rear left caliper replacement bolts?
Hello, I'm looking to replace the top and bottom bolts on my caliper as the bottom was rusted (but removable) and the top I had to cut off completely.
I see in another thread here that the top bolt is an M8x21, and bottom is M12x1.5x35, can anyone confirm before I run out to a hardware store?
Here is another parts image, but no model #'s are listed for 1 and 6, which are the bolts I need.
I'm not the original owner of the car and don't have an owner's manual, so I don't know whether the bolts that were installed are OEM.
Yep, both #'s 1 and 6 are what I need to replace (top and bottom bolts).
Thanks for the link, I have some part #'s to look up.
6 N 101 815 02 bolt, with hex. socket hd. M10X1,25X40 2
- N 102 409 01 bolt, with hex. socket hd. M10X1,25X65 2
New bolts come with a new carrier or if you buy a rebuilt loaded caliper.
I've made it a habit to check/lube the pins yearly when I swap rims after having a rear pin rust/freeze in the carrier forcing a full replacement.
N'Syncro
33
02-16-2020 03:12 PM
Optimusglen
09-02-2015 07:24 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
