Last edit by: IB Advertising
- Audi A3 How to Install Backup Camera<br>Step by step instructions for do-it-yourself repairs.
$170 Reverse/Backup camera kit and install
#172
#173
#175
Relay: http://amzn.com/B007JPPQH6
From the image, wire 87 should connect to the green wire.
#176
Your normal MMI works right? Just black screen when camera "turns on?" I'm having a similiar situation which is turning out to be a faulty loose wire. Or it might be the camera went out. Contact the seller, they were really helpful with me last time I had questions.
#177
Yeah, tried flipping all the switches, removed the shrink tubing to make sure there was no stripped wires. No luck so far.
#178
Any idea what wire yours was?
#179
Hello,
thank you for the reply mroberte, is it problem with the seller no send from belgium :/
I have receipt my camera kit and i have one problem, look my video for explain :
Do you have one solution for my problem ?
#180
Hello,
Caméra de recul AUDI A3 8V - YouTube
Also check the black cable that goes from the black box to the MMI unit as that is the cable that provides the video to the screen.
I was having a very similar problem when I took my car into service... the upgraded the ECU which changed the reverse canbus signal. So the box can detect it for a second, but then turns off, then you get just a black screen or it goes to one of the stock screens. Using the reverse gear signal with relay should alleviate this problem now.
