How to mirror your phone on the MMI screen
#52
I am confused, because the phone's micro usb is being used by the HDMI output dongle. Also I purchased the suggested HDMI RCA converter and mine has a female MINI usb port which it is unclear whether that is power out or in. PS: The Goliton? did work in my car. I got the unsupported message. Going to spring for the Audi part and see if i get better results.
#53
Oh, I see, you don't have an iPhone.
Here's what I was saying:
I don't know how it would be done on an Android, but it probably depends on which one it is.
- Apple realized if you were to use video out, you'd want to charge the phone at the same time
- They invinted the lightning port that could do lots of different things based on the chip inside the cables
- Their HDMI adapter has a port you can plug a Lightning cable into such that you have charging and HDMI out in one port.
- The HDMI to composite AV converter has a micro-USB port
- So, in this case, you use a two port 12VDC to 5V 4A charger and run a USB-Micro USB cable to the HDMI converter and a Lightning cable to the Apple HDMI adapter.
#54
#56
Of course Mark is right on. What I do is add a dual port high power 12VDC USB charger the pictured USB cable plugs into and then add a lightning cable on the other USB out and plug it in below the spot where the HDMI plugs into on the Apple adapter
#58
Well, with Audi's Google Earth you can, but you can't listen to non phone audio and display phone screen. You can use an app like tune in radio from your phone and Google Maps on your phone
