Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
S3 and shuffle
Old 09-14-2015, 05:42 AM
mhblaw's Avatar
Default S3 and shuffle
My wife has a new S3. Wanted tunes in it but didn't want to use her smart phone or spring for a $150 i pod. So I bought a $50 i pod shuffle, got the $67 connector from Audi, downloaded her tunes to the shuffle and installed in car. Worked great...until the next day, deader than a stone. Switched the shuffle on and off and worked...until the next time she tried to turn on. So, not sure what I doing right or wrong. Suggestions? I have an i pod in my RS 5 and has not missed a beat for over two years.
Old 09-14-2015, 07:27 AM
markN1689's Avatar
Make sure you are in Media mode
maybe try uploading to sd card?
Old 09-14-2015, 08:44 AM
arU4ic's Avatar
MMI crashes the music app at times on my iPhone about once or twice per month I have to reboot the phone.
If she isn't disconnecting and reconnection a lot, not sure what else could be going on unless you bought a non-OEM cable.
I highly second the SD card option or even better, copy them to the hard drive, you get great functionality, album art, album browsing, etc.
Old 09-14-2015, 11:27 AM
STItoS3's Avatar
Like others said, just get a $20 SD card. The MMI has a shuffle feature.
Old 09-14-2015, 12:19 PM
mhblaw's Avatar
Not sure I understand the "shuffle feature" of the MMI. The MMI manual does reference using the I pod shuffle so I assume it should work. Just don't know why it does work and then does not.
Old 09-14-2015, 08:36 PM
arU4ic's Avatar
You are right, it should work for sure. I recommend that she detach it before she gets out of the car, a PITA I know, but that should solve the problem.
Old 09-15-2015, 07:05 AM
mhblaw's Avatar
Yes, we have decided that is the best solution, even as said a PITA.
DaGrandMastah
Q5/SQ5 MKI (8R) Discussion
14
10-05-2016 05:53 PM
EJAZ
Misc. Models Discussion
06-29-1999 11:10 AM
Quick Reply: S3 and shuffle
