Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
42 Draft Designs Introduces the Audi A3 3" Turbo-Back!
Old 09-15-2014, 10:22 AM
Former Vendor
42TT's Avatar
Default 42 Draft Designs Introduces the Audi A3 3" Turbo-Back!
We're both excited and proud to announce the release of our 3" Turbo-Back for Audi A3!
Bolt-On Power and Torque
When designing the 2.0T FSI & TSI motors Audi thankfully increased the size of the K03 turbocharger. Unfortunately they designed the exhaust like a brick wall. Rule #1 in turbocharger theory is reduce backpressure at the turbo discharge. With the factory exhaust installed, exhaust gases exit the turbo and wastegate only to meet a dense catalytic converter. By increasing the size of the piping to 3" and moving the catalytic converter further away from the turbo, exhaust gases can mix naturally and develop momentum before being filtered through the catalytic converter. The result is useable power and torque throughout the powerband, quicker throttle and boost response.
Attention to Detail
Starting at the turbo, a CNC machined flange allows gases to merge naturally into a tight radius bend. The second bend transitions the downpipe neatly through the exhaust tunnel, separated by a stainless steel flex section. Underneath the car, a custom tabbed flange and CNC machined hanger assembly allow the downpipe to be supported by the factory hangers. Bolting to this flange, a Magnaflow 200 cell metal catalytic converter takes care of harmful emissions without creating a restriction. Along the way, precisely placed oxygen sensor bungs allow for factory fitment of the oxygen sensors on both FSI and TSI motors. Exiting the catalytic converter, a long offset pipe meets an adaptor allowing precise fitment to the cat-back exhaust. Double layer graphite gaskets and grade 5 locking hardware keeps everything tight.
Construction:
Construction Highlights
CNC mandrel bent aluminized steel tubing
CNC waterjet cut 1018 cold roll steel flanges
Professional TIG welded construction throughout
409 stainless steel 200/cell metal catalytic converter
Stainless steel double-braided flex section
High-temperature vermiculite gaskets
Grade 5 locking hardware
CNC machined hanger assembly cad/zinc plated steel
Construction Highlights (Stainless Steel Upgrade)
CNC mandrel bent 304 stainless steel tubing
CNC waterjet cut 304 stainless steel flanges
Optional CNC machined male/female v-band flanges
Stainless steel hardware & copper coated locking nuts
CNC machined hanger assembly stainless steel
Includes:
-Complete Exhaust Assembly
-Catalytic Converter OR Test Pipe
-Resonator OR No-Resonator Pipe
-Hanger Bracket & Hardware
-Exhaust Gaskets & Locking Hardware
-Exhaust Tips & Exhaust Clamps
Pricing:
Audi A3 FWD Turbo-back starting at $985
Audi A3 FWD Downpipe starting at $450
Audi A3 FWD Cat-Back starting at $565 (Also available in slip-fit)
Audi A3 Quattro Turbo-back starting at $985
Audi A3 Quattro Downpipe starting at $450
Audi A3 Quattro Cat-Back starting at $565 (Also available in slip-fit)
ORDER NOW!
Optional Accessories
O2 Sensor Spacer
For more information, further construction details, and FAQs please visit our product page located here.
42TT
TT (Mk2) Discussion
06-01-2015 02:32 PM
42TT
09-15-2014 10:53 AM
42TT
09-15-2014 08:26 AM
Lechlis
01-22-2013 06:20 PM
LBW
A4 (B7 Platform) Discussion
11-02-2005 01:28 PM
Quick Reply: 42 Draft Designs Introduces the Audi A3 3" Turbo-Back!
