Audi A5 indicator fault (59 plate)
Good evening,
My Audi indicator has started playing up and it has come to the point where it can be quite dangerous.
I indicate left and it turns the right side on.
Other times I indicate right and the left will come on.
And then some times it doesn't indicate at all.
The only time I seem to get a nit of normality is when I hold down the indicator and put the steering wheel on to full lock until it clicks. This seems to reset the fault for a little while.
I know that this is obviously something to do with the switch at the base of the stem but is this an easy fix or a pain in the ****?
Any help would be greatly received. Thank you.
AudiWorld Expert
I think it is more complicated than I would attempt. Here is my write up on replacing a steering wheel on a RS4 which is the B7 body not B8 like your car. You can see what things look like with the wheel removed
AudiWorld Tech Articles
Audi A3 Audi A3 steering wheel
dantheman1250
02-24-2019 02:35 PM
shepherd850
01-09-2012 07:26 AM
LakeShow41
A4 (B8 Platform) Discussion
04-17-2008 01:23 PM
bierTT
03-02-2006 02:57 PM
