Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
A5 2007 Advanced Key problems after battery change
Old 01-22-2013, 10:02 AM
Trebax's Avatar
Default A5 2007 Advanced Key problems after battery change
Hi there,
I'm hoping someone can help me... I've search several forums with this problem but with no luck...
I have an Audi A5 2007 with the advanced key - with start/stop button. Recently the battery went flat on the key fob - I know it was the battery because I received a number of warning messages on the dash reminding me to replace the battery. However, I didn't change the battery in the key fob in time and I had the battery completely run flat on me at a time where I was unable to get a replacement battery...
So I had to unlock the car using the metal 'turn key' that is usually housed within the key fob. Then I had to insert the key fob into the ignition to start the car. It was like this for about 24 hours until i replaced the battery in the key fob.
However, with the new battery the 'advanced key' functions do not work: opening the doors, start stop button etc. Also on the dash it says 'no key identified'.
I'm guessing that the key has been reset and needs re-programming? However, I'm yet to find a working re-programme guide?
Please can someone offer (a novice) some advice here??
jbansal
A7
11-08-2016 09:54 AM
JFD
Q7 MK 1 Discussion
01-07-2015 09:36 AM
Dreamer99
Q5/SQ5 MKI (8R) Discussion
04-23-2012 10:55 AM
greyjag
01-30-2011 06:58 PM
S5X
06-12-2008 10:53 AM
Quick Reply: A5 2007 Advanced Key problems after battery change
