Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Oil Problems with 2012 A5 Cabrio
Old 07-25-2014, 01:45 PM
LiLxAmy's Avatar
Default Oil Problems with 2012 A5 Cabrio
I have a 2012 A5 cabrio. I always take the car to an Audi dealership to take care of all maintenance issues. I had the 15k maintenance done at 21k. That included an oil change and a check for everything else. My car just hit 25k.
Now I am getting a warning light saying my oil is low. I went under the hood to look for the dipping stick.. (There was none! &#128517 so I figured out that I had to look on the screen. The oil check bar was empty. Is there something wrong with my car? How could I be empty on oil in 4k miles? What should I do? (I'm not a car person and don't know much about fixing them) 😓
Old 07-25-2014, 02:00 PM
uberwgn's Avatar
These 4 cylinder engines consume oil. Get the dealer to top off for you or obtain an oil that meets VAG 502.00. Is that simple enough?
BTW, if your post suggests that you went from 5k miles to 21k miles without an oil change, that's not a good strategy
Old 07-25-2014, 07:15 PM
LiLxAmy's Avatar
Default 😳
No I didn't go from 5k to 21k 😜 I went at 5k, 13k to 21. But the dealer is telling me I can go every 10k. If that's the case, then how come I am getting that low oil warning. Also what kind of oil do I need to get? 😅 I was going to get 5w40 synthetic oil, European blend.
Old 07-25-2014, 07:27 PM
LiLxAmy's Avatar
What does it mean to meet VAG 502.00? 😅
Mobil 1 - European Car formula, advanced full synthetic motor oil, 0w40 or 5w40? Is that one ok? Also what does viscosity mean?
Old 07-26-2014, 04:15 AM
uberwgn's Avatar
Originally Posted by LiLxAmy
What does it mean to meet VAG 502.00? ��
Amy, 502.00 is the spec that describes the oil used in your engine.
The most common, IMO, is Mobil 1 0W40.
As long as you see "502.00" on the bottle, you are good to go.
You can also purchase from the dealer's parts counter if you are more comfortable with that.
Walmart, NAPA, Advance Auto Parts and Autozone all sell the Mobil 1 product I mentioned above.
Old 08-03-2014, 10:44 PM
lramos98's Avatar
Put a quart of oil in it and check the level once a month to monitor the level. There is no dip stick. You'll be fine. I had a 2010 Audi A4 that consumed a quart of oil every 2,000 miles. My oil level would be at the bottom and after I put a quart of the recommended oil it would fill back up until I drove another 2,000 miles or so. Once you put the oil in it , the computer won't be able to read the new level for about a day or so. The next day check the level and you'll see your level back up
zub3qin
05-24-2011 12:41 AM
villainS4
15
01-31-2004 03:25 PM
bryantchoung
Audi allroad
9
06-11-2003 06:59 PM
dgo6spd
Audi allroad
03-14-2002 05:12 PM
Quick Reply: Oil Problems with 2012 A5 Cabrio
