AllRoad not starting
Old 10-06-2015, 06:54 PM
Ottoman56's Avatar
Default AllRoad not starting
Hello all. I have a 2001 allroad 2.7t. When I drive the car long enough to get it up to normal temperature, when I turn it off, after about an hour it won't start again. When it completely cools off it will start again. I am stumped. I tried a coolant temp sensor, fuel pump, fuel pump relay. No luck. I have figured out that when the car does not start, it cranks but does not seem like it is getting gas. I took the rear seat out when I changed the fuel pump. When it does not start I do not hear any noise from the fuel pump. Then when the car cools off and I try it again, then I can clearly hear the fuel pump working.
Any help would be greatly appreciated.
Old 10-07-2015, 08:43 AM
amiram's Avatar
If you have the option check for fault codes
Old 10-07-2015, 09:12 AM
Ottoman56's Avatar
The only code is p0491. That is the secondary air system fault. I replaced the secondary air pump and the fuse. When the car is cold I hear the pump run. What is interesting is that I disconnected the battery and just yesterday the check engine light came back on. It is still the p0491 code?
Old 10-07-2015, 08:22 PM
amiram's Avatar
You must delete the fault code, disconnecting the battery does not erase the code.
In this forum has a number of trades that are dealing with "engine not start" You'll find the answer there.
Old 10-08-2015, 04:58 AM
Ottoman56's Avatar
I have looked through every forum that talks about engine not starting. I have replaced every part that I have read might be the cause. Throwing parts at this car is getting expensive. I was hoping for a new idea as to what my problem might be. It seems to me to be a pretty particular case. What makes a car not start an hour and a half after you shut it off? Then, give it another hour and it starts right up? I have not seen that in a forum any where.
Old 10-09-2015, 05:17 AM
Kneale Brownson's Avatar
Google Audi Allroad engine speed sensor.
Old 10-28-2015, 01:52 PM
Ottoman56's Avatar
Turns out it was the Anti theft module in the key.
Old 10-28-2015, 11:47 PM
audi-1norway's Avatar
try to ckek the camskaft sensor, it has build in a security to prevent engine damage, in another car of my friend he changed the knocking senor on the camshaft and that resolved his issue
Old 01-11-2016, 10:36 AM
dexter.mac130@gmail.com's Avatar
How did you diagnose and fix this?
I suspect mine is doing the same, as I recall the guy I bought the car from mentioned something about it.
Kongen
A4 (B8 Platform) Discussion
09-17-2015 12:23 PM
blink
10
09-14-2015 02:00 PM
Avantadrive_Original
A4 (B7 Platform) Discussion
09-14-2015 12:11 PM
9552T500
09-08-2015 05:41 AM
jonathanheierle
09-07-2015 09:09 PM
Quick Reply: AllRoad not starting
