AllRoad not starting
Hello all. I have a 2001 allroad 2.7t. When I drive the car long enough to get it up to normal temperature, when I turn it off, after about an hour it won't start again. When it completely cools off it will start again. I am stumped. I tried a coolant temp sensor, fuel pump, fuel pump relay. No luck. I have figured out that when the car does not start, it cranks but does not seem like it is getting gas. I took the rear seat out when I changed the fuel pump. When it does not start I do not hear any noise from the fuel pump. Then when the car cools off and I try it again, then I can clearly hear the fuel pump working.
Any help would be greatly appreciated.
The only code is p0491. That is the secondary air system fault. I replaced the secondary air pump and the fuse. When the car is cold I hear the pump run. What is interesting is that I disconnected the battery and just yesterday the check engine light came back on. It is still the p0491 code?
You must delete the fault code, disconnecting the battery does not erase the code.
In this forum has a number of trades that are dealing with "engine not start" You'll find the answer there.
I have looked through every forum that talks about engine not starting. I have replaced every part that I have read might be the cause. Throwing parts at this car is getting expensive. I was hoping for a new idea as to what my problem might be. It seems to me to be a pretty particular case. What makes a car not start an hour and a half after you shut it off? Then, give it another hour and it starts right up? I have not seen that in a forum any where.
Avantadrive_Original
A4 (B7 Platform) Discussion
09-14-2015 12:11 PM
9552T500
09-08-2015 05:41 AM
