Anyone know G290 temp sensor resistance?
Old 06-24-2013, 08:03 AM
  #11
Former Vendor
ArnottDoug's Avatar
Originally Posted by aTOMic*
Yes, Arnott shows visually identical compressors for MB and my A8L at $375 and $875 respectively, only apparent difference is 3 wiring connectors and 2 hoses which I suspect one could transfer from old to new pumps... but it's be a $300 gamble.
At their core, they are very similar. The differences are the mounting brackets, the intake hose, wiring harness connections and attached thermistor. The MB pump (P-2192) does not use a thermistor.
Remember, Forum members can use code AUDISAVE12 to save up to 10%* off the retail prices on Arnott's Audi products. You can place your order online at the Arnott Web Store or by calling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00 AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the same day. (This code will not work on Mercedes-Benz products such as the compressor.)
*Max savings $75 per order, not valid with any other order or on shipping, taxes or core deposits (if any).
Old 03-13-2015, 02:58 AM
  #12
x3noc's Avatar
Default Temp Sensor
Hi Folks,
I've got the same problem on my Q7. The sensor is showing an increase in resistance as it gets hotter. The problem i have is it seems to be a non-replaceable part. I can get it out but its just a solid blob.
Do i risk trying to make a new one rather than shell out the £400 for a compressor i dont need...
Ideas on a post card :-)
Jason
Old 03-16-2015, 04:35 AM
  #13
bagpipingandy's Avatar
Originally Posted by x3noc
Hi Folks,
Jason
Hi jason, the resistance (ohms) should get less as it gets hot (closer to zero)
what are the error codes? do you get over heat straight away with the key on, or only after the compressor is running for a while?
does the compressor ever run with the key out the car?
if it is just a faulty sensor, i have old compressors i break for spares, send me an e-mail or a photo of the sensor to see if i have the correct one for your car,
let us know what the error symptoms are 1st to make sure the compressor is not actually overheating.
regards
Andy
lane09
TT (Mk2) Discussion
02-11-2018 04:25 PM
Neo1130
07-14-2008 12:21 PM
egp320i
05-29-2005 01:00 AM
red90q
01-30-2005 03:36 PM
egp320i
02-04-2004 09:04 AM
Quick Reply: Anyone know G290 temp sensor resistance?
