Codes Galore
Codes Galore
My CIL popped the other day coming home from work. I had bought the car in Jersey, and drove it all the way home to CT with no problems, except for the bouncing shocks from a failing compressor. The car ran beautiful, with maybe a slight hesitation when accelerating. Probably the turbo lag that I'm not used to yet. Here's what I pulled:
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 A
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02335
VCID: 4189557B4BCED82921E-5140
WAUYP64B61N****** AUZ7Z0Y1497962
8 Faults Found:
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-00 - Open or Short to Plus
17867 - Exhaust Gas Temp Sensor 2 (G236)
P1459 - 35-10 - Implausible Signal - Intermittent
17870 - Exhaust Gas Temp Regulation for Bank 2
P1462 - 35-10 - Implausible Signal - Intermittent
17869 - Exhaust Gas Temp Regulation for Bank 1
P1461 - 35-10 - Implausible Signal - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 35-10 - Mechanical Failure - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-00 - Insufficient Flow
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-00 - Insufficient Flow
Readiness: 0000 1000
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0101
Coding: 00001
Shop #: WSC 00000
VCID: 2D5119CBE7562C49F56-4B00
1 Fault Found:
01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
28-10 - Short to Plus - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655 C
Component: Airbag Front+Kopf 1000
Coding: 00307
Shop #: WSC 02335
VCID: 4FAD63438D9A3E59A7A-519A
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
64-10 - Not Currently Testable - Intermittent
Address 34: Level Control Labels:
VCID: 55A1912BAC4644896D6-5124
Note: Excessive Comm Errors
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02335
VCID: 306F00BFF06441A1DE0-4ECE
3 Faults Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D02
Coding: 01186
Shop #: WSC 02335
VCID: 020B9A770E480331784-5140
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
I haven't driven the car since I cleared them all, because the front end is just about scraping the ground. I know I need to check all of the fuses first, and try re-soldering the EGT. But with all of the other electrical issues, is there maybe a master ground issue? The battery had been replaced as well, so that may explain some issues.
Coding: 06752
Shop #: WSC 02335
8 Faults Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 00307
Shop #: WSC 02335
1 Fault Found:
Coding: 15885
Shop #: WSC 02335
3 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
Coding: 01186
Shop #: WSC 02335
1 Fault Found:
A lot of those codes could have been set a long time ago. Only a few will trigger a CEL
Now that you've cleared them, drive it, and see if any recur over the next few days. Chase those down, and fix things.
A run down battery some time in the past can cause a lot of error codes. So many of what you have are intermittent, so clearing and rechecking later is the best option.
That's what I figured. It wasn't a good sign that the dealer had a jumper box in the back seat when I picked it up. Once it gets above 4 degrees out, I'll rebuild the compressor, and take it for a spin.
Dave4roma
54
09-19-2011 07:45 PM
S4Rules
09-19-2005 06:30 AM
UnoDosTurbosQuattro
Audi allroad
9
04-01-2005 08:42 AM
SmokinS4™
12-25-2002 10:47 PM
