Help! 2001 Allroad Ignition problem
So today when I went to start my car the ignition seemed to be locked, like when you just need to jiggle the steering wheel to turn the key. I jiggled the steering wheel and there was still some resistance, but I tried to turn the key anyway and I think I broke something inside the ignition? Is this even possible?I heard a snapping noise and the key will turn to starting postilion, all electrical items, radio, windows, dash lights, etc work but the car makes no attempt to start. What did I break? I haven't even owned this car 2 months. . . .
As you mentioned, a qualified Audi tech should be able to fix or replace it. My 02 allroad has never had an issue with the ignition switch so an OEM replacement should last a loooong time.
I would not be afraid of removing an airbag...just careful. Make sure you disconnect the battery first, and keep you face clear as you unbolt it. Once you remove the bag, carefully unplug and put it in a safe place. Do not connect the battery until the airbag is back in place.
Should be a pretty easy repair once you get to the part. I wouldn't think you need to remove the air bag.
these are the parts you would need
https://www.carpartsdiscount.com/cat...ml?3593=512960
https://www.carpartsdiscount.com/cat...ml?3593=137729
use this code (4FVL7K) at checkout to received 10% off your order for being a forum member!
JakesGirl
05-22-2009 12:34 AM
ursusarticus
11-21-2005 07:50 AM
