Level control module bad? Code 00775
Old 02-25-2015, 11:17 AM
vtraudt's Avatar
Default Level control module bad? Code 00775
2003 Audi Allroad. Getting error code
First thought the sensor itself (corroded, wires, sensor internals), but reading the Rosstech description, could it be the module?
Is there a way to test the module (VAGcom or else)?
00775 - Level Control System Sensor; Rear Right (G77)
57-00 - Electric Circuit Failure
00775 - Level Control System Sensor; Rear Right (G77): Implausible Signal
Possible Symptoms
 Malfunction Indicator Light (MIL) active
Possible Causes
 Communication Problem between Level Control Module (J197) and Headlight Aim Control Module
 Wiring/Connectors from/to Level Control Module (J197) faulty
Possible Solutions
 Check Communication Problem between Level Control Module (J197) and Headlight Aim Control Module
 Check Wiring/Connectors from/to Level Control Module (J197)
Old 02-26-2015, 03:33 AM
bagpipingandy's Avatar
Possible Symptoms
Possible Causes
Possible Solutions
Not sure how to test the module other than swapping the ECU, but you have more chance checking the level sensor, VCDS reading the values
other thing to check:
their is a joint connector to that sensor under the rear bench seat, make sure it is not corroded/damaged
you could swap the sensors from another corner to see if the fault code moves corner
also i have read a rear right level sensor can be a red herring for a fault in another module, any other faults stored elsewhere, ABS or other?
regards
Andy
Old 02-26-2015, 03:49 AM
amiram's Avatar
Default Height Level Control System
Before you test (Disassemble\Disconnect parts) the Height Level system you must put the car to a "Jack mode" to Prevent damage.
Old 03-09-2015, 07:56 PM
Banned
PaperToast's Avatar
'65535 - Internal Control Module Memory Error' is the failed module code
check the connections and wiring to the level sensors, never hurts to put some dielectric grease in the connectors to help water proof them
Paramount Motors
12-08-2011 06:08 PM
SpyderTurbo
Audi allroad
17
12-16-2010 06:04 PM
xtreetoes
Audi allroad
03-13-2007 06:57 AM
malcho
05-20-2003 07:46 AM
Quick Reply: Level control module bad? Code 00775
