What is this part? What is this white deposit?
#11
Part identified
2001 allroad 6MT, engine code APB
Last night before quitting, I discovered (photos below) the suspicious white powder deposits on tubing and fittings I can't identify next to the firewall. To my amazement, I then noticed a broken fitting adjacent to the deposits. Bright orange innards waving around in the air, seeking attention. This doesn't strike me as a coolant line, but frankly I'm otherwise clueless as to the source of the deposits. Whatever it is, it needs to be replaced!
After a fruitless trip yesterday to Premier Motors (Audi Dealer), I came home and verified the identity of the broken fitting. In retrospect, it was all fairly obvious, and I'm probably who broke it. Nonetheless, the part number is 078 133 753A. As PaperToast suggested, it's a brake booster check valve. The dealer's only offer was to order the entire assembly for $186.63, including tax, and that after I walked them through finding the part on their own computer! Thanks.
The final solution, I believe, comes from a thread originated by rskelme, in 2007. The cheapest option I found was a Chinese part on eBay for $6.99. Think I'll pass on that. I rather like the 'champagne cork' option devised by rskelme, and think I'll try that.
Thanks, everyone!
Last edited by Stubborn, but Happy; 06-02-2015 at 02:50 PM. Reason: Insertion of photo
#13
No obvious leak from photos...
I take that back about the leak. The clamped hose in the bottom of the 2nd photo is pretty crusty where it attaches. And the background appears wet throughout the photo. Take the pump off and see what's underneath...
#14
I realize this thread is drifting but...
the pumps are dry underneath, no signs of crust or anything. The pump on the lower left in that photo does have a bit on the connection, it's true.
However, I might be onto the problem. A while back I stripped the bleeder screw and had to replace with a standard metric bolt. I picked up another at the dealer a while back, but the parts guy had trouble tracking down the right one and supplied what he thought was the right one. It's not. When the reservoir is opened, you can clearly see coolant gurgles up from this bolt. I tried twice to make sure. I then swapped my standard bolt solution back in, no gurgling.
So now do I replace the pumps anyway since I'm this far into it?
#15
#16
As detailed below, I replaced the faulty bleeder screw with my jury-rigged solution (a bolt.) No leak so far. I think the screw might actually be a problem with the threads in the female end, not the bleeder screw itself.
dorsal900
12v V6 Discussion
10-03-2008 01:09 PM
huwla
09-17-2003 04:38 AM
