Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
won't accelerate properly
Old 02-12-2015, 09:11 AM
  #11
tonycosta1984's Avatar
Goheels, I'll check today if it happens when the engine is cold. I'm also curious as to all the parts you have replaced in search of fixing this problem. Is your ecu chipped?
My engine is stock minus the apikol coil harness and 4.2 coils.
I also double checked the plugs and they're a little worse than I remember, So I ordered some f5dp0r plugs because I heard those are the best plugs to run on a stock aan.
I'll let you know how it turns out.
Old 02-12-2015, 12:26 PM
  #12
GoHeels's Avatar
I'm running an MTM 1+ setup from Hoppen.
Things I've replaced or worked on -
- new Bosch sport bypass valve
- 3 silicone boost hoses with quality clamps
- silicone intake hose (air-box to turbo)
- LS2 ignition system
- running the DTC spark plugs
- replaced the N75 valve
- replaced some vacuum hoses around the engine bay
- replaced the O2 sensor, which fixed my issue for a few days, and to me helped rule out a boost leak
- replaced blown tee hose and PCV bits under the manifold, which helped
- tested spark strength with cheap flaps tester
- new fuel filter
- new Bosch fuel pump
- new CPS, if that matters at all
All I can think of at the moment.
Old 02-12-2015, 10:38 PM
  #13
Yeah the miss is still there when the engine is cold
Old 02-13-2015, 07:39 AM
  #14
UrS4boy's Avatar
I just typed a nice story that Audiworld lost for me somehow. ( ) Bottomline was you might have a valve issue that goes away when the engine is up to temp. Do a compression test on your AAN, both cold and warm (hot) to see the difference.
Old 02-18-2015, 02:40 PM
  #15
sanadrustom's Avatar
Hey guys
I also have the same issue, if I floor it from let's say 2k rpm it's fine till 4k then starts bucking and if you keep your foot down it smooths out and accelerates. I checked the injector's resistance and they all came in around 17 ohms that means they are working but not necessarily clean. Reason I say that cause the rpms fluctuate at idle back and forth from 800-1000. I'm starting to get curious at possible solutions as its getting warm slowly out and would like to tinker till it's fixed.
I'm running 1.8t coil pack. I know I need to do a leak down test and what not but I did the napkin test at the tail pipe and it didn't get sucked is so a burnt valve is ruled out no? Please say yes lol
Anyways this is a good thread I keep checking it daily hope to do Daves recommendation soon in a weeks time
Just a thought...could be bad cats? Reason I ask is there is a rattle in my cats when I rev the car and all heat shields are removed.. Could it simply be that the cat isn't breathing properly?
Just a thought
Thanks guys
Old 05-29-2015, 07:50 PM
  #16
lliejk's Avatar
My problem was coils (on 2 separate occaisions). I used the last procedure to discover which one. I would start there and then move to the others if that does not turn up the culprit. I used some old spark plugs and lamp wire to ground out the plugs not being tested. Good luck.
Ed
A diagnostic procedure for engines that are missing or hesitating
________________________________________
Welcome to the "joys" of UrS-car ownership. This is a likely a minor problem but it will take a bit of time, effort and money to solve.
Missing and/or hesitation is often related to a Power Output Stage (POS) problem or a coil problem but it could be spark plugs, coil to plug boots or even the MAF to turbo hose or the MAF connector.
In fact, before you even start looking at the ignition as the source of the problem, remove and check your MAF to turbo hose for rips or tears. If you find something, replace with OEM (not cheap). Aftermarket silicon MAF to turbo hoses are usually only for big honking turbos not a K24 or RS2 turbo.
The other thing to check at start is the harness to MAF connection. Sometimes the male pins of the MAF miss the "target" on the female pins and end up pushing the female pins backwards, out of the harness MAF connector. If that is the case, all sorts of weird missing happens (poor connection) and maybe even a 4411 code (i.e. injector No. 1 fault). The solution is to clean the connection (male and female pins) and then after reconnecting, pushing the female pins individually, from the back of the connector towards the MAF to make sure they are properly mated with the male pins.
There is more MAF info HERE
Coils usually are fine at idle and low boost and then have a problem under boost, whereas the POSs will have problems at idle AND under boost. However, the only way to tell is to test each component:
Generally, missing is either a fuel or an ignition problem. Fuel problems can come from dirty/malfunctioning injectors, clogged fuel filter or bad fuel pump.
Fuel filters are cheap (from VM Autohaus in Burnaby, at least). Unless you know the fuel filter to be good, I would just replace it now. Order a filter and the two copper crush washers. Start the cold car and then pull Fuse No. 17 in the drivers side end of the dash. This stops the fuel pump and the engine will run until the pressure at the injectors is too low. Then turn off the ignitiion and slowly break the fuel filter connections (I think one of the wrenches is a 14 mm) slowly, with a rag to catch the remaining fuel drips. R&R the fuel filter see if the problem goes away.
Injectors can be checked by removing them and testing the spray pattern, looking for one that is just dribbling instead of producing an atmomizing spray. This can be done in the engine bay, provided some precautions are taken.
I don't think its the fuel pump so leave that alone until the ignition system is confirmed good.
The ignitions system is comprised of the ECU (computer) that controls the delivery/timing of the spark, the Power Output Stages (POSs) which are transistorized switches controlled by the ECU, the coils, the coil to spark plug boots and the spark plugs.
On an unknown (or a new to you) car, it is probably smart to install new plugs and maybe spark plug boots. The ONLY plugs that work without problems are the Bosch F5DPOR. If necessary, follow the noobie procedure I wrote up on Audiworld:
Link to a spark plug replacement procedure
If you haven't done the plugs and boots, then do them and then retest the car. If you still have a problem, then it is either the one of the two POSs or a coil (or coils).
The POSs are both three channel. One does cylinders 1,2 and 3; the other cylinders 4 and 5.
The first POS check is at idle. Remove the injector connectors one at a time, noting when the idle roughness gets worse. If it does that eliminates that cylinder as the problem, reconnect the injector. When you disconnect an injector and the roughness is the same, note that cylinder number and reconnect the injector. Its either going to be a POS unit or the injector (hopefully there is only one cylinder with a problem).
The second stage of this test is to swap the connector on both the POS units and redo the injector disconnect test. If the missing cylinder moves, then it is a POS. If the missing cylinder is the same, then it is likely an injector (assuming you have installed new plugs and boots)or coil.
If the miss does move, you have one free position on one of the POSs that you can use. For example, if the miss was on cylinder 4 at the start and then it moves to 1,2 or 3 after the POS connector swap, you can swap the connectors back and move the cylinder 4 input and output pins to the empty position 6. You can also do this if the miss was on 1, 2 or 3 and then it moves to 4 or 5. You just leave the connectors in place and swap the pins on the new problem cylinder. If after you swap the connectors and the miss on 1, 2 or 3 goes away, its because the missing cylinder is now connected to the spare channel 6.
If none of this works, it may be more than one POS channel. In which case, you need at least one new POS. The correct POS is a 4A0 905 351A, however, the cheaper, 4A0 905 351 POSs from a 92-97 V6 wasted spark (fires two cylinders at once) ignition system will work on our cars, as a substitute for our 4A0 905 351A.
To check the coils, the simplest way is to swap in a known to be good coil pack (two POS connectors and two (one?) ground connection). If problems go away, then you know its one (or more) of your coils. Otherwise, to test your coils, you need to remove the coil pack cover as in the spark plug replacement instructions. Inspect all the coil wiring for signs of cracking (a known failure mode). If the wires are cracked, replace the problem wire (same or thicker gauge) by soldering and heat shrink tubing (remember to get the tubing over the wire BEFORE you solder - (don't ask)). If the wires appear fine, then with a friend, and an old fashioned coil spark tester (see photo below), connected to one coil at a time, and with the fuel pump fuse (No. 17 left hand dash panel) pulled out and four old spark plugs in the other four boots (ground plugs to cam cover to protect the coils), check to see which of the coils has the weakest spark (the one that only jump the smallest gap) by having your friend turn the ignition to start and cranking the engine while you look for the coil that gives the weakest spark. This will be your culprit. Replacement coils need to be spliced in with soldering and heat shrinking.
Old 05-29-2015, 08:07 PM
  #17
UrS4boy's Avatar
Originally Posted by lliejk
My problem was coils (on 2 separate occaisions). I used the last procedure to discover which one. I would start there and then move to the others if that does not turn up the culprit. I used some old spark plugs and lamp wire to ground out the plugs not being tested. Good luck. Ed.
Ed: Please either give them the real link or me the credit for writing that procedure (thanks).
One missing and hesitation diagnostic procedure HERE
Old 06-02-2015, 10:33 AM
  #18
Default It was a boost leak for me
It ended up being a ripped boost hose for me
Old 06-02-2015, 06:11 PM
  #19
GoHeels's Avatar
No surprise, mine blew in the same spot. Time for silicone.
Old 06-03-2015, 04:50 PM
  #20
lliejk's Avatar
Sorry about that Dave. I had copied and pasted that into a doc and sometimes I miss the header from the post.
I will be more careful in the future.
This was a good write up by your friend, Dave over on the other forum.
Ed
emmett03
12
02-10-2009 04:27 PM
jrv666
07-03-2008 11:16 PM
alpinab7
10
08-20-2005 03:09 PM
td80
01-04-2003 07:24 PM
Quick Reply: won't accelerate properly
