Last edit by: IB Advertising
- Audi How to Recondition MMI Display<br>Step by step instructions for do-it-yourself repairs.
MMI Display Refurbish
#41
Procedure for removal of a trim
You need something like this
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
http://www.amazon.com/s/ref=nb_sb_no...m+removal+tool
Thanks a lot for the help man, but i have an aditional question.
I already bought the plastic wedges for removing the trim but i couldn't find the T40207 hook tool neither on Amazon or Ebay.
Does anybody know where i can find online the T40207 hook tool or a similar one that could replace it???
Thanks again.
#42
Thanks again.
Thanks again.
http://www.amazon.com/s/ref=nb_sb_no...ds=Hook%20Tool
or
Easy from thicker strings you make yourself hook tool
#43
Here you have a lot of similar tools
or
or
Thanks a lot man. Now i have everything for my project !!!
#46
I wanted to resurrect this thread to let folks know that there is a <$100 solution to a scratched MMI LCD display.
Rather than replacing the entire unit which can cost $1000-1400 new, you can replace just the LCD display panel.
Once the unit has been removed, you can remove the outer frame. The underlying TFT panel is an AUO unit. My particular S4 uses a AUO C070VW04 V6 7" TFT LCD Panel Display. The replacement can be found at many locations if you google it.
When the unit arrives, it can be swapped out by pulling out one wire and feeding a flat wire tab which is secured under a screw unit.
#48
Interesting! Thanks for sharing this!
#49
Does this AUO TFT display have the same blue coating found on the factory units? It's this blue coating that many people have scratched. Until now the only cost affective fix was to rub off all the blue stuff entirely.
