Old 07-25-2016, 03:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Specifications & General Maintenance
Print Wikipost
Q5 FSI Carbon Build-up
Old 01-19-2015, 12:37 PM
  #321
ELEVENS's Avatar
Originally Posted by HZ60
No apologies needed. After enduring 5 carbon cleanings, you are clearly the undisputed resident expert Carbon Meister!
5 - ouch. I guess I never looked at it that way!
Old 01-19-2015, 08:42 PM
  #322
ryanaudi's Avatar
Originally Posted by hojbjerg
Indieq5,
What app and obd2 dongle are you using?
Thanks
"I bought Automatic https://www.automatic.com/ for my Q5 afterwards to get the codes before taking it in and the fault codes it gave were P0491 / P0492."
Old 02-27-2015, 06:33 AM
  #323
fritz1515's Avatar
I'm considering purchasing a 2010 Q5 with 74k miles. This carbon issue has me concerned. Does the warranty extension Audi has offered to cover this issue apply to the 2nd and 3rd owner or just to the first? Is there any quality after market warranties out there people have used for piece of mind? Also the Carfax has no mention of ever having a carbon cleaning, would that even show up? Any advice on this purchase would be appreciated.
Old 02-27-2015, 07:49 AM
  #324
Resoom's Avatar
You could try having your local dealer run the VIN, I'd imagine any warranty work would appear. Even better if the vehicle was sold/serviced form that same dealer. When I bought mine (there is only one dealer in town), I called them and got a full service history.
Old 04-03-2015, 03:04 PM
  #325
tcrider's Avatar
I'm in the process of cleaning my valves. do you have to rotate the crankshaft? I just clean what I understand is the cylinder 4 valves without moving it. Is there a risk of the cleaning fluid( brake cleaning parts) to leak inside the engine?
I'll stop for today and continue Sunday. Any input will be appreciate it.
Thanks.
Old 04-14-2015, 12:14 PM
  #326
tcrider's Avatar
Ok, so I found out that my 6 cylinder valves where actually open, so I rotated the engine and cleaned that one. Then I proceed to clean the injectors. Right bank I replaced one injector and cleaned the other two. Since I had them out it was easy to clean the tip and run injector cleaner through them. I didn't change the combustion chamber seal since I don't have the tool for it. For that reason I cleaned the left bank injectors without taking them out. I put everything together and turn it on. So far runs like a charm.
I also downloaded the Carista app and cleared the codes.
Thanks again to everyone that contribute to this matter.
Old 04-14-2015, 06:07 PM
  #327
ELEVENS's Avatar
tcrider, did you take any photos of the carbon buildup on the intake valves? I've not seen any pics of the 3.2 carbon. Now the RS4 on the other hand.... ohhhh boy does it get choked up in a hurry!
Old 04-15-2015, 10:09 AM
  #328
tcrider's Avatar
not a great pic. but you get the idea
After clean up.
injector going bad?
I hope this pics upload correctly... Not the best quality, but you get the idea.
Old 04-15-2015, 10:19 AM
  #329
ELEVENS's Avatar
Thanks for the pics. Interesting. Looks mostly oily but not the rock-hard stuff I'm used to scraping off the RS4 valves. The thickness of the coke doesn't look all that bad either, although the valves are not very visible in the photos.
How many miles? Based upon the photos, I don't think I'd even bother cleaning the intake carbon.
Old 04-15-2015, 11:23 AM
  #330
tcrider's Avatar
Once I started scrapping them a lot of carbon came out, so I cleaned them anyways. The car has 89K miles and I hope this was the only time I do it.
Quick Reply: Q5 FSI Carbon Build-up
