Last edit by: IB Advertising
- Audi Q5 Common Problems<br>Important information to help you understand your Audi Q5.
Q5 FSI Carbon Build-up
#301
They don't have to pull the motor anymore. "All" they have to do now (with their special-built Audi carbon-cleaning tool) is to pull the entire front end off your can to get to the exhaust ports. It's a bit easier and takes less time than pulling the motor. Still a several-day job though! Either way, quite invasive indeed.
#302
Anyone who can help. 09 q5 3.2, MIL came on Sunday morning, pulled code at a local auto parts store and came up with the dreaded p0491. I am at the Audi dealership as we speak, I have done several hours of research and worried it is carbon buildup. Audi stated it is under warranty but have to diagnose it for themselves, which I totally understand. My question is this, I only have one code, p0491 and not p0492. Could the generic reader only have pulled one or could this problem be something different that "worse case" where they have to pull the engine. Just want to be educated before I hand over the keys.
#304
CB
The Audi dealer offers an induction service (about $200) that is intended to clean out CB (U-Tube has a couple of excellent videos).
The technician needs to be thorough to get all CB out and careful not to damage catalytic converter.
Not sure how good this service is after the CB is too much. It appears that doing this as preventative maintenance might be a better strategy.
Many people gun their engines from time to time to burn the CB out.
Wishing you best of luck
#305
#307
Carbon isn't an issue on the TDI, the DPF (diesel particulate filter) is the topic that comes up most frequently there. I think the current gen shouldn't have an issue with it anymore due to the car not letting the regen cycle get interrupted, but it's something to be aware of (and the typical prevention step is to occasionally keep the load on the engine high to heat up the exhaust and help anything caught in the filter get burned up -- regen will do this on its own from time to time, but it doesn't hurt to help things along).
#308
The Induction Service that many Audi dealers offer consists of running chemicals through intake plenum to cylinders. The intent is to clean up the CB. Check out U-Tube to see how it is done. Audi charges about US$200.
I do not know why they call it Induction Service. ;-).
If interested in this service, Pls be very careful who does it for you since chemicals can damage catalytic converter.
The best option is having Audi get into the head and engine to clean the CB.
Wishing you best of luck.
#309
We specifically went TDI to reduce risk from CB.
As you suggested we'll do the "Italian tune up" aka "a redline a day keeps Audi doctor away"
#310
In fact, the Induction service does little to nothing to the carbon problems in the induction system of Audi's FSI motors, such as in my RS4. This is not only widely reported, I know this first hand. Over several thousand miles, I've introduced multiple cans of Seafoam, BG Induction Cleaner, GM Induction cleaner, and gasoline into the induction system on my RS4 using a special port located at the rear of the intake manifold. The port is located such that it discriminates cylinders. IOW, the distribution is not uniform over all 8 cylinders so the effects of the chemicals appear at the rear cylinders. Subsequent tear downs and inspections showed the effect of the chemicals were, at best, a slight softening of the carbon. That makes the dirty, tedious job of manually scraping the carbon off the intake valves and intake ports every so slightly easier. The Q5 may too have this problem but the 3.2 SAI carbon problem is so much worse, it overshadows any intake carbon problem.
So in a nutshell, Induction Service on an FSI Audi is a financial enrichment program for the dealer. It probably does wonders to clean the throttle body plate. A $4 can of aerosol TB cleaner is more thorough and MUCH cheaper! These aren't pre-FSI motors we're talking about where induction service actually work quit well. I believe that's the problem in its entirety with the whole Induction Service thing. It's a well-know solution that was proven to work on NON-FSI motors. Even respected mechanics not up to speed on FSI technology, mis-advise Induction Service for FSI motors because it worked so well up to this point (Audi FSI motor).
