Removing Front License Plate Filler
Old 04-13-2014, 09:01 AM
stash64's Avatar
Default Removing Front License Plate Filler
My front filler had the paint peeling problem around the video sensors. The replacement piece is here and I've found that the filler piece simply snaps off and on. However, the video sensors come with it. Does anyone know how to remove/disconnect the sensors ?
I'm hoping the sensors simply snap or twist on/off but I'm not too anxious to start pulling or twisting without some idea.
Old 04-13-2014, 09:21 AM
spijun's Avatar
I took off and it was easy
Old 04-13-2014, 04:33 PM
stash64's Avatar
Thanks !... not sure what is meant by "remove air intake grill", but I think I can do this by just detaching the filler plate from the grill. There is not much slack in the sensor wiring but should be enough to get at the snaps holding the sensors in place.
Old 04-14-2014, 03:06 AM
spijun's Avatar
Originally Posted by stash64
Thanks !... not sure what is meant by "remove air intake grill", .....
This is only an option when removing front grille.
You have a enough length of wiring, you can remove sensor
choppstixxx
Q5/SQ5 MKI (8R) Discussion
16
05-05-2021 05:29 AM
Blackwood
10-24-2018 03:24 PM
kingcardin
05-20-2015 08:41 AM
Jbidwal
07-01-2011 03:06 PM
khogz
10-04-2006 10:41 AM
Quick Reply: Removing Front License Plate Filler
