Adblue Pump Problems
I have a 2015 Q5 TDI that I purchased brand new and picked up in September of 2014, have had the vehicle replaced back in November of last year because of transmission issues, and since then I have had the Adblue code show up twice in my vehicle. Audi has been great at replacing the pump without issue, but this time the code popped up after they changed the pump when they took it for a test drive. Looks like the issue will need further troubleshooting and they need to escalate to Audi Canada. Apparently there is an issue with the pumps, not sure if others are in the same situation. I saw some threads on other Audi lines. Wanted to get a discussion started for the Q5's.
Not even 100 miles into our 2015 Q5 TDI, the car threw a code on my wife's way home from work:
1 Fault Found:
9645 - Reductant
P20E8 00 [237] - Pressure too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 44 km
Date: 2014.10.17
Time: 09:08:39
Readiness: 1 1 0 0 0
Audi replaced the reductant (Adblue) pump & gasket and all has been just fine since (~4K miles now). I chalked it up to a case of infant mortality but I suppose there could have been a bad batch of pumps out there too. We took delivery in mid-October (car ordered in July and built in Sept) if that info helps any.
1 Fault Found:
9645 - Reductant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 44 km
Date: 2014.10.17
Time: 09:08:39
I had the same adblu fault pop up 3 times. Dealer replaced pump every time. I opened a case with AOA with an attorney and they agreed to replace my vehicle. This time i asked for a 3.0T instead of TDI as the experience was bad for me. SUrprised to see these issues popping up more often.
1 Fault Found:
9645 - Reductant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 44 km
Date: 2014.10.17
Time: 09:08:39
1 Fault Found:
9645 - Reductant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 44 km
Date: 2014.10.17
Time: 09:08:39
Interesting.
I have both my 2014 TDI and 2015 TDI Adblue sensors replaced as well..before they hit 10K
Thought it was weird....dealer said it wasn't an issue. GO FIGURE!?!?!
All cars have a lot of parts in them, and QC is never 100% no matter how hard you try, so part failures are going to happen. What matters is that the incidence rate is as low as possible and the manufacturer takes care of the issue if it's obviously not just "wear" and cracks the appropriate heads in the supply chain if there's a bad lot (vs. one or two individual parts).
Have had this issue many times on the 335d. Urea is relatively new technology for cars. Urea crystallizes very easy and messes up pumps and sensors. These are all issues that should be covered under your emissions warranty.
