Fuel Tank Cap lock repair
Hello!
My Q5's fuel tank cap doesn't lock or unlock. This is a very common problem on Q5 and other Audi models like A5, A4 B8 and A6.
I got to fault on VCD:
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 80
Mileage: 82204 km
Time Indication: 0
Date: 2012.12.03
Time: 20:43:46
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 82204 km
Time Indication: 0
Date: 2012.12.03
Time: 20:44:08
I know that I have to replace the lock (Servo element). The part is: 8K0 862 153 E
I have look to the inside of my trunk and remove the right side panel. My doubt is what I need to remove to reach the servo element and replace it. Anyone have do this repair?
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 80
Mileage: 82204 km
Time Indication: 0
Date: 2012.12.03
Time: 20:43:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 82204 km
Time Indication: 0
Date: 2012.12.03
Time: 20:44:08
Droscheautomobil (07-18-2022)
Thanks guys, especially Spijun. (Who's English is still far better than that of many people living here.(G)
Now I guess I'll have to order a special Audi Fuel Filler Compartment Drain Tube Snake to get that hose unclogged. But at least I know which quadrant to go looking in.
I believe you wanted to so do in the post your started about the water drain.........
A small update since this is a frequent issue on Q5s, mine included.
Revised replacement is 8K0 862 153 F.
After ordering the part number, I managed to fix the old part number with WD40 as seen in youtube video. First checked that the solenoid gets power when locking and unlocking (trembles), then tried 3 in 1 oil but did not work (too thick) then I got the WD40, put the straw inside the back opening, and sprayed the internal mechanism.
Worked. A five minute job.
The moral of the story, try to fix this before ordering a replacement part. I managed to received a refund, since seller did not dispatch .. Happy that this issue has been sorted out.
