4 Wheel Brake Pad and Rotor Replacement
I'm looking to change the front and rear pads and rotors on my 2011 TDI Q7.
I have a 2 post lift in my garage and have done this on several other cars of different makes but never an Audi, so I have a few questions.
Is there a DIY video on how to do this? I've seen several for the pads but none for the rotors.
Seeing that the vehicle uses one piece wheel studs, do the callipers have to be unbolted to remove the rotors or can you remove the rotors with the callipers in place?
Are there any special tools required?
If the callipers have to be unbolted, where can I get proper torque numbers for re-assembly?
Thanks in advance for any help.
Jonathan
Jonathan
I have a 2008 q7 and I'm doing the same project as you. I did the fronts a few days ago which ended up being easier than i thought. Normal tools nothing out of the ordinary. When i took off the rear wheels i noticed the bolts were different and that i did not have the proper tools for. I ended up ordering the following which i was told from another forum will have the right sockets to complete the job. I planned to complete the rears this weekend if not tonight so i can let you know how it turn out.
Capri Tools XZN Triple Square Spline Bit Socket Set, Metric, 10-Piece - - Amazon.com
I'm going to order a set of impact grade longer bits (XZN400 XZN 9 pcs).
When you did the fronts, did you have to loosen the bracket holding the connection of the flex hose and the rigid line going to the calliper? If so, what bit was required to loosen it?
Well as of last night I was able to complete the rears with the tool in the link I posted. Worked awesome, I'm happy I bought it. As for taking brake lines or anything else off there was no need. I hung the caliper using a long wire tie. You definitely need a long braking bar for the rear bolts but nothing else. I do highly recommend getting all new hardware there was no need to use the old ones.
i plan on doing this soon also:
Radguy can you list all the new hardware items you ordered (retaining clips etc)
Icon the link does not come up??
I ordered the triple square 10 piece set but I see Radguy said to get longer ones ?? are these really needed or will the regular set work just fine ??
thanks
thanks
I did not need the long ones. The ones I ordered in the link worked out fine for me. If you need to add an extension to the ratchet you can always do so if you think it will help. As for the hardware its actually a kit look it up on line you will see it. You don't need anything more or less than what it comes with. Good luck
thanks
thanks
Front kit:
Audi Q7 TDI Braking Caliper - 7L0698269A - Brake Hardware Kit - ES#414747
Rear kit:
Audi Q7 TDI Braking Caliper - 7L0698269 - Rear Brake Hardware Kit - ES#252204
The front kit is Audi OEM, the rear kit is aftermarket.
excellent thanks .. what do you guys recomment for crossed drilled rotors ?? im presuming I will be coming up to changing brakes soon (@ 60k) and I might as well set it up nice with some good rotors and ceramic pads .. thanks in advance
I ordered the hardware kits from ECS Tuning.
Front kit:
Rear kit:
Front kit:
Rear kit:
mrprism133
09-07-2015 07:22 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
