Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Battery dead and doors locked..2007 Q7.. Help..!
Old 03-26-2015, 05:21 PM
SSLVR's Avatar
Default Battery dead and doors locked..2007 Q7.. Help..!
Someone somewhere must have had to deal with this before..The Q sat for a couple weeks without any use.. Now the battery is totally dead and doors will not open. I do not believe I can access the hood release cable, already had a peek behind the front left wheel housing..and no sign of it..I tried all the keys I have in the drivers door manual key cylinder, keys go in fine but do not turn at all...any ideas would be greatly appreciated...
Old 03-26-2015, 09:52 PM
smith2010Q7's Avatar
the electronic part in the drivers door is a switch that tells the other doors to unlock, but it should not keep you from opening the drivers door. You have to try a little harder in turning the key. Also same way on your rear hatch.
Old 03-27-2015, 08:27 AM
B490MTL's Avatar
Did you ask the same question on Kijiji? If the barrel doesn't want to turn, most likely someone in the past tried breaking in your truck by forcing the keyhole with a screwdriver. You will need a tow truck driver to open the door because there is no other way to get in.
Old 03-27-2015, 09:23 AM
SSLVR's Avatar
Thanks for the advice..I just needed to try a little harder turning the key...Just being a little too careful.....Thanks..Problem solved...
Old 03-27-2015, 07:37 PM
AudiWorld Expert
iconoclast's Avatar
where is the keyhole for the cargo area / hatch / trunk?
Old 03-27-2015, 10:22 PM
B490MTL's Avatar
There is none, only the driver door. Mine also won't turn but clearly someone took a screwdriver to the keyhole and tried to force it open.
Old 03-29-2015, 07:37 PM
imjustdave's Avatar
If its like the VW .. a part turn is basically Electrical swith telling the car to unlock, but 2x the distance of turn is actually mechanically unlocking the door.
Old 03-30-2015, 04:48 AM
AudiWorld Expert
iconoclast's Avatar
my apologies, i misread "truck" as "trunk". lol.
AbuKhan
Q7 MK 1 Discussion
04-03-2017 01:15 PM
haltsu83
02-04-2017 02:11 AM
pbcsd
S4 (B8 Platform) Discussion
01-25-2014 08:02 PM
alternety
11-24-2010 01:59 PM
radhaz
08-13-2006 02:24 PM
Quick Reply: Battery dead and doors locked..2007 Q7.. Help..!
