Conoco gas/check engine light?
Anyone have this happen? Just moved from N. Cali to Littleton CO....car was shipped out. Running fine. Put gas in for the first time at Conoco (93) and a day later, check engine light comes on. Seems to be staying at higher RPMs before shifting, too.
Suggestions? Help? Advice?
Other gas station options locally are: King Soopers, Valero. Would have to drive a good way for Chevron. Was using Arco in Cali. Never had a check engine light come up on this vehicle.
2007 Q7
Thanks in advance!
2007 Q7
Thanks in advance!
Ultimate Keyboard Warrior
FWIW, Conoco is a Top Tier certified gasoline.
And I got a CEL in my 2013 S5 a few weeks ago, which required several parts to be replaced per TSB.
I'd check the obvious if you don't have access to a scan tool, like fuel filler cap. I had to replace the fuel filler cap on the 3.6 to cure a check engine light (I scanned it with my VAG-COM first). I am assuming that I will be replacing the 4.2's cap soon, as the rubber seal has many cracks.
Carlos Ramirez
Q7 MK 1 Discussion
06-18-2007 08:06 AM
MikeNSX
Audi 100 / A6 (C4 Platform)
04-16-2004 09:36 AM
jayel
09-07-2002 07:57 AM
hanrahje
11-25-2001 03:01 PM
Chris K.
12-28-1998 09:11 AM
