Q7 no start, no communication
#11
Thank s so much again for taking your time to help me out. I probably should have mentioned I am not a pro, just a guy trying to rule out as many problems before this car gets shipped to the dealer. As I mentioned previously, there is no communication from the car. I have checked for power and ground at the port and its fine. I am wondering how to physically check the j520. Looking at the pin assignment on the j520 I see only a few pins used. However, one caught my attention which is the glove box unlock motor activation. Mine is currently not working and was before. I guess my question is.. if I check for power and or continuity at pins 105 and 113 (can-h and can-l) will that give me aome insight as to the functionality of this module (j520)? Sorry in advance if this is a completely ridiculous and naive question. Thanks again
Q7 Glove Compartment Cover Emerg.pdf
The motor is on it own, looks like water damage.
Q7 Glove Compartment Unlock Motor.pdf
adjust the cable
Q7 Glove Compartment Cover adjustment cable.pdf
NewOwnerA4Cab2009 (02-19-2021)
#14
Thanks. I appreciate it. I did. There were a few blown, power outlets, I replaced them. I just saw that the j520 is fuse 5 in carrier 1. That was visually ok, but I will test that one.
#16
Everything that I am reding talks about no power to the ECU. attach is a relay J271 in the ECU.
Motronic Engine Control Module (ECM) Power Supply Relay -J271-
Check this out.
Q7 Relay and Fuse Carrier Electr.pdf
Check this out.
#18
Check this out.
Attachment 45615
Check this out.
Attachment 45615
#20
I pretty sure you have check this. under driver seat main fuse links and power supply relay
Q7 Relay and Fuse Carrier Below driver.pdf
