TDi fuel filter change
#11
Great information. I am going to be due for service (55K major maintenance) on my 2011 Q7 TDI, from what I can gather the following items need to be replaced:
Air filter
Spark plugs
Oil & Oil Filter
AdBlue fluid refill
Cabin filter
Fuel filter - remove water only
Did I miss anything?
Also, does anyone know the torque specs for the spark plug?
Thanks!
Air filter
Spark plugs
Oil & Oil Filter
AdBlue fluid refill
Cabin filter
Thanks!
Fuel filter complete replace not just water.
#12
Thanks, wishing I read this earlier, I already ordered the glow plugs, still I wonder why the owners manual calls for replacing the glow plugs at the 55K service.
#13
Air filter
Spark plugs
Oil & Oil Filter
AdBlue fluid refill
Cabin filter
Thanks!
Air filter
Spark plugs
Oil & Oil Filter
AdBlue fluid refill
Cabin filter
Thanks!
#14
Also, the 2011 doesn't have a water separator. Just a paper element for a fuel filter. Re-read my original post for an explanation on how to change it.
#15
I just finished up the oil and filter change. Now I am ready for the fuel filter change but I have some questions:
-are the input and/or output lines to the filter pressurized with diesel fuel
-do you need to pinch the fuel lines before removing them
-can you use VAG software to prime the new fuel filter
-also, does anyone know where the cabin filter is located for the 2011 Q7 TDI (this also part of the 55k service)
Thanks in advance
Thanks in advance
#16
I am not up to speed for the fuel cause I still have Audi Care, but this web sit is good for your cabin.
Cabin Filter Replacement: Audi Q7 2007-2014 - 2009 Audi Q7 Premium 3.6L V6
#18
2011 Q7 TDI Priming
Old thread but wanted to update for others. I have a 2011 Q7 TDI and I just changed the filter. I heard people say the ignition could prime it and they do it 3 times and others say you need to run it the pump using a scan tool. I have ODBeleven so I wasn't worried either way, but I did find out by accident the ignition will activate the lift pump, but just not right away.
I had my hood up after the install so I could put my hand on the filter to feel it being purged in case it was hard to hear. I flipped the ignition on and went straight to the filter. While waiting for ODBeleven to connect and searching thru the output tests I heard the pump kick on and purged out all of the air before it kicked off. It kicked on about 60 to 120 seconds from flipping the ignition.
I then ran the lift pump with ODBeleven which runs it for a while about 10 seconds on 5 seconds off for a while. I didn't hear any more air purge during this process so I think the ignition activation took care of most of it.
Just a heads up if you don't have a tool to trigger the pump yours may be similar and the pump kick on from the ignition, though it may take a minute or two before it kicks on. I suppose you could repeat the process a few times to make sure it is fully purged.
#19
I am also planning to replace my fuel filter. I have 2014 Q7 TDI 3 lit. I am only afraid of $7000 fuel pump replacement cost after reading this thread.
- I want to know if my primary/low pressure pump will run by ignition switch?
- Do I need VCD If I take care of filling up the new filter with fuel and also the lines before putting it back? (I dont have VCD) Have one but says does not include model Q7.may be old version.
- does tiny amount of air in pipe if left over is that critical .
- I am going to fill up the new filter and piping ends before putting it togather.
- are the rubber clamps of 2014 fuel filter (Filter is like a inline aluminum tube) simply pulled up to remove them?
Thanks,
Thanks,
#20
I just pinched off the fuel lines with these: https://www.harborfreight.com/4-piec...set-65116.html
then replaced the fuel filter with a new one the same way I took the old one off, plus I wrote millage on it w/a sharpie.. I have a VCDS, I didnt use it.. just cranked it til it started and all was fine.
