Cleaning intake valves on the Q7
Anyone done this? Any useful DIY threads?
... with that in mind, is there Any benefit to using BG 44k on a 3.6 FSI Q7?
Cheers
The carbon build up in the intake and on the intake valves is a result of their being no fuel vapor in the intake to clean away the oil blow by created by the positive crankcase ventilation system. All of the direct injection engines have the potential to develop the problem but all of them do not exhibit it. A properly functioning PCV system is important to reduce the amount of oil blow by to the intake. Some engines simply have more blow by and consume a bit more oil than others due to production and wear variation. More blow by will introduce more oil to the intake and with no fuel vapor there to constantly clean it, carbon will accumulate. BG44 might help to prevent the problem but it will have to be sucked into the intake via a vacuum port. Putting it in the fuel will do nothing as it will never contact the area with the carbon. Only manual cleaning is going to correct that.
Cheers
While not the same engine, I came across this yesterday and it was helpful to give me an idea on how the basics of it are done.
https://www.audiworld.com/forums/a6-...clean-2764902/
BG44 is a very good gas (not diesel) additive. I used it all the time on my Volvo 2.9l engine. It does clean and it does a good job for preventing carbon build up. I used it at every 4000 miles. Now if I had to go deep into the engine it will have to be a cel code or engine not running right or feel right.
BG44 will not fix a cel code but it can prevent it.
Go to the BG website for your nearest distributor.
https://www.bgprod.com/contact-us/distributor-locator/
I already bought it, its just that with a direct fuel injection engine the 44k never touches the intake valve.
I was wondering if anyone knew how to go in manually and clean the valves individually.
AudiWorld Expert
it is not very difficult to do but it is time consuming and arduous. i opted to have a local independant shop perform this since they are better equipped and more experienced. it should run between 900-1400 depending on how badly they are choked. i had it done for the Q7, RS4, S5. all variants of the same engine/system.
there are several DIY for the B7 RS4 engine. very similar process.
if you do it yourself purchase all new hardware & gaskets. pour in two bottles (15g) of techron before the cleaning and perform an oil change after the cleaning and test drive.
(the techron is just a detergent for any leftover residue that may have been floating around. the injectors do not hit any valves so it will not help with the cleaning of them but any gunk or debris that may have found it's way into the system or around from the cleaning would be cleaned out.
|skolnick
Audi Original "S" Cars
08-30-2007 09:05 AM
