Help !!! ESP and ABS lights are both On - advice needed
Both ESP and ABS Lights came on. I had a friend pull the codes and had 1 Fault Found:
01276 - ABS Hydraulic Pump (V64) Electrical Problem in Circuit
What could be wrong is this an easy fix ?
01276 - ABS Hydraulic Pump (V64): Signal Outside Specifications
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
ABS Hydraulic Pump (V64) Connector to Control Module faulty
Wiring and/or Connector(s) faulty
ABS Hydraulic Pump (V64) faulty
Brake Electronics Control Module (J104) faulty
Possible Solutions
Check ABS Hydraulic Pump (V64) Connector to Control Module
Check Wiring and/or Connector(s)
Check/Replace ABS Hydraulic Pump (V64)
Check/Replace Brake Electronics Control Module (J104)
01276 - ABS Hydraulic Pump (V64): Electrical Fault in Circuit
Possible Symptoms
Possible Causes
Fuse(s) faulty
Ground Spots corroded
Wiring and/or Connector(s) from/to ABS Hydraulic Pump (V64) faulty
Possible Solutions
Check Fuse(s)
Check Ground Spots
Check Wiring and/or Connector(s) from/to ABS Hydraulic Pump (V64)
Special Notes
Explicitly check the Fuse(s) near the Battery!
01276 - ABS Hydraulic Pump (V64): Implausible Signal
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Check Ground Spots
Special Notes
Possible Symptoms
Possible Causes
Fuse(s) faulty
Mike00S4
05-23-2005 09:20 PM
Whirly
01-16-2004 07:16 PM
