Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
No front AC this morning, no fan. Rear operating fine though
Old 07-25-2015, 11:27 AM
aubiexx's Avatar
Default No front AC this morning, no fan. Rear operating fine though
2009 Q7TDI. We have noticed when very hot outside that the front fan won't turn on sometimes. When this is the case, it later will turn on after driving for a minute or so.
Below is from my vag-com. Ideas?
01273 - Fresh Air Blower (V2)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 4
Reset counter: 30
Mileage: 176881 km
Time Indication: 0
Date: 2015.07.11
Time: 09:49:52
Freeze Frame:
Temperature: 28.0°C
Speed: 0.0 km/h
(no units): 67.0
Load: 0.0 %
00003 - Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 176768 km
Time Indication: 0
Date: 2015.07.07
Time: 12:53:24
Freeze Frame:
Old 07-25-2015, 04:12 PM
markray's Avatar
You need to replace the blower motor, easy job, I'm on my second blower
Old 07-25-2015, 10:17 PM
B490MTL's Avatar
Very easy, half an hour and done. I purchased a TYC aftermarket on eBay for 70$ I think, lifetime warrantied. Good enough for me. The size of the socket is 5.5 mm, if you don't have it go in the SAE.
Old 02-02-2016, 06:16 PM
brucebanner's Avatar
i have the same issue. does anyone know if the part is the same from 07-14? i have a 2011. most say the part is compatible with 07-10
Old 02-02-2016, 07:43 PM
B490MTL's Avatar
Should be the same, ask the seller first or check if the part number matches
Old 02-03-2016, 12:42 AM
Corimal's Avatar
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 30
Mileage: 176881 km
Time Indication: 0
Date: 2015.07.11
Time: 09:49:52
Freeze Frame:
Temperature: 28.0°C
Speed: 0.0 km/h
(no units): 67.0
Load: 0.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 176768 km
Time Indication: 0
Date: 2015.07.07
Time: 12:53:24
Freeze Frame:
Same issue with my MY08 - fan wouldn't work when outside temp was hot, then started later in the drive. Over recent weeks has made whirring sounds then stopped. Has been intermittent but now completely stopped working. Hoping it's covered under warranty!
Old 02-03-2016, 10:43 AM
igotag's Avatar
Old 02-04-2016, 07:24 AM
cmarshack's Avatar
I just replaced mine last week...v easy job!
I used this fan:
Robot Check Robot Check
And bought this 5.5mm nut driver:
Xcelite 55MM Metric Nutdriver with Drilled Shaft, 5.5mm Hex, 76mm Working Length, Black Handle: Nut Drivers: Amazon.com: Industrial & Scientific Xcelite 55MM Metric Nutdriver with Drilled Shaft, 5.5mm Hex, 76mm Working Length, Black Handle: Nut Drivers: Amazon.com: Industrial & Scientific
Old 09-06-2016, 09:00 AM
kkbma's Avatar
Hi there,
I have to replace mine, but Amazon says the part you bought is not compatible with my 2010 TDI, what year do you have? I can't find my part (4L1820021A) on Amazon at all, but would really love to get it there if possible.
Thanks,
Kimber
Old 09-08-2016, 08:38 AM
69RS's Avatar
The fan in my 144k miles 2011 TDI just died. The one I picked up at the dealer was 4L1-820-021-B , parts guy said it is the latest version.
Quick Reply: No front AC this morning, no fan. Rear operating fine though
