Tuesday,30,April,2024,19:48:55:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN:
WAUZZZ4F49N011001 License Plate: A6
Mileage: 252480km-156883mi Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4F 52 53 55 56 5F
62 69 72 76
VIN:
WAUZZZ4F49N011001 Mileage: 252480km-156883miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (CAJ) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4F1 910 551 HW: 4F1 907 551 B
Component: 920l V6 TFSI 0030
Revision: --H01--- Serial number:
Coding: 0105000C190F0920
Shop #: WSC 66565 257 00032
VCID: 6099A09DD6405DDA6FB-8034
VINID: 9D196AAAA11610978004100004A0312E95
2 Faults Found:
006410 - Coolant Pump for Intercooler
P190A - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 252485 km
Time Indication: 0
Date: 2024.04.30
Time: 19:32:01
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 82.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
000024 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
P0018 - 000 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 252485 km
Time Indication: 0
Date: 2024.04.30
Time: 19:32:01
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 152.6 mg/str
Temperature: 73.5°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI RdW 0020
Revision: --H04--- Serial number: 4486515
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2C0104ADEA08C9BA833-8078
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0004537
VCID: 6E85CEA51C94FBAAED7-803A
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601205518
Coding: 0000003
Shop #: WSC 02323 785 00200
VCID: 2517F18989E2F8F25CD-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000030392521
Coding: 0524294
VCID: 1D67D969A1B2303204D-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0033122
Shop #: WSC 11111 111 45799
VCID: 34311CCD3238917ADB3-8060
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 11111
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 11111
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000011
VCID: 211FE59991CA14D2205-8074
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000 Dataset Number: 4F0909602AA 0011
Coding: 30314236303630303031554A304C34463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU56.rod
VCID: 303910DDCAA0AD5ABFB-8064
Crash sensor for side airbag: driver side:
Serial number: 3574SRB4000082AD31DA
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3584SRB4000082CC9A5J
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35152RB402L7EMTAOJVM
Passenger side rear thorax airbag crash sensor:
Serial number: 35252RB40337EMTANK3L
Crash sensor for front airbag: driver side:
Serial number: 3554NRB400004584D973
Crash sensor for front airbag: front passenger side:
Serial number: 3564NRB400004589F195
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055082620137
Coding: 0002041
VCID: 270BFB81F3EEEAE26E1-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 933 K HW: 4F0 920 933 K
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9FY0725A8
Coding: 0F5F0A050A000008000000
Shop #: WSC 02399 823 56573
VCID: 2F3B13A1D71EB2A2A61-807A
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L089220049
Coding: 000303
VCID: 323D1AD5C42C9F4AC9F-8066
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Serial number: 00000000002730329111
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001151691
Coding: 00581300004011110000
VCID: 313F15D9C12AA452B05-8064
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100335700
Coding: 011F02205E40410001
VCID: 46D5560558A413EA757-8012
2 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 133
Mileage: 252478 km
Time Indication: 0
Date: 2024.04.19
Time: 20:21:00
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 252485 km
Time Indication: 0
Date: 2024.04.27
Time: 15:03:45
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01149961290000
Coding: 0139397
Shop #: WSC 02335 785 00200
VCID: 353721C939428872ECD-8060
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000416879
Coding: 0001004
VCID: 5EE59E65EC346B2A5D7-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100286529
VCID: 45D7510965A218F27CD-8010
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 133
Mileage: 252478 km
Time Indication: 0
Date: 2024.04.19
Time: 20:24:05
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 131
Mileage: 252478 km
Time Indication: 0
Date: 2024.04.19
Time: 20:24:10
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000221
Shop #: WSC 02145 785 00200
VCID: 211FE5999DCA14D2205-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000026
VCID: 698FBDB9257A1C92B85-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H43 0020
Revision: AB001007 Serial number: 342JZ087515465
Coding: 010003020100000000
VCID: 1F1BE361A7BE2222161-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 666 B HW: 4E0 035 666
Component: H-BN-EU H60 0047
Revision: -------- Serial number: 345J.087526426
Coding: 010100000202C1ED41000F0DEF6300030001
Shop #: WSC 43991 142 84695
VCID: 2517F18985E2F8F25CD-8070
Subsystem 1 - Part No: 8R0 060 884
Component: EUROPE 2008 5505
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356IM081009204
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 S
Component: Bedienteil MM H01 0060
Serial number: 00000001190463
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100334492
Coding: 010E00204040220001
VCID: 43D34F116B9626C2529-8016
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100338056
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 131
Mileage: 252478 km
Time Indication: 0
Date: 2024.04.19
Time: 20:21:09
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 R HW: 4F0 919 283 R
Component: Parkhilfe 8-Kan H12 0300
Revision: 00H12000 Serial number: 11630827401894
Coding: 0211006
Shop #: WSC 131071 102 209715
VCID: 33331FD137369642C29-8066
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 172
Mileage: 252485 km
Time Indication: 0
Date: 2024.04.22
Time: 16:45:00
End----------(Elapsed Time: 01:42, VBatt start/end: 12.0V/11.9V)-----------
