Any recommendations for Heating/AC install in Denver? Affordable & AC are the key aspects
Old 06-25-2007, 09:13 AM
Member
orangefro©'s Avatar
Default Any recommendations for Heating/AC install in Denver? Affordable & AC are the key aspects
needed...
Thanks in Advance.
In the mean time, I am thinking cold thoughts to help with the heat....
<img src="http://pictureposter.audiworld.com/104791/nooneisgettingout.jpg">
Old 06-25-2007, 09:49 AM
cpayne's Avatar
I have used Nationwide on 2 homes...been happy both times
Old 06-25-2007, 09:58 AM
DUBITUP's Avatar
Default Hey Sean, you renting right
is the owner kicking in?
If not, I'd get a portable...Home Depot/Lower/Sa,s Club/Costco has a few that are decent.
We used to use 2 portables, for approx 700sqft. and they did OK for a smaller place, I think it was around 1500sqft. it would get the house comfortable, IIRC around 76-78ish
Old 06-25-2007, 10:31 AM
Member
orangefro©'s Avatar
Default Yeah, he is kicking it all in. I told him if he put AC in, I would stay there...
He likes me, I pay rent early, I fix stuff myself and I don't bother him. I am the perfect Bish...
Old 06-25-2007, 10:32 AM
Member
orangefro©'s Avatar
Thank you for the suggestion.
Old 06-25-2007, 10:37 AM
Junior Member
Ginseng Sniperâ„¢'s Avatar
Default Call Bob...
303-650-6121 - He is a friend's father. He is a licensed HVAC guy and does side work for cheap. Bob Eads (son's name is Dion). Tell him that Matt Cerone (Sur-own) sent you...
Old 06-26-2007, 09:09 AM
Elder Member
green_vaccine_old's Avatar
2nd, so damn hot in the city with no AC
Old 01-05-2015, 10:40 PM
jarome ingala's Avatar
Default AC install
Installing an AC unit in a vehicle is a complex process. You should not attempt doing so until you are well aware with your vehicle's system. Always choose a good, reliable supplier for your ac system's parts. Plumbing needs to be done neatly and methodically for an ac system to perform at its peak. Air Conditioning Repair Miami can provide trusted and qualified ac repair specialists for your ac installation.
Old 03-03-2015, 08:35 PM
Michelle Barrows's Avatar
If you want your AC unit to work perfectly for a long time, you will have to take proper care of it. Any AC unit needs regular cleaning and care. You can also manually clean up your AC unit if you have knowledge about AC and stuff. If air conditioning repair is done regularly, the costs of ac repair will be affordable every time
Old 03-10-2015, 04:29 AM
Matt Khasidov's Avatar
Originally Posted by orangefro©
needed...
Thanks in Advance.
Give proper care to your HVAC unit , do service from well certified AC repair Company so that your AC unit will provide you efficient cooling and heating.
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
xkahn
02-08-2018 10:43 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: Any recommendations for Heating/AC install in Denver? Affordable & AC are the key aspects
