RS 7 Discussion forum for the Audi RS 7
Sidewall bubble/tire pressure on RS7
Old 05-05-2014, 06:20 PM
GTS00021's Avatar
Default Sidewall bubble/tire pressure on RS7
Recently had to get a tire replaced on my RS7 (21" rims) due to a sidewall bubble. On a hunch i checked the tire pressures via the MMI and they were 49 psi all around. I thought i read somewhere that overinflation can make bubbles more common.
Anyway...what are you RS7 fellas with factory 21s running pressure wise? if im reading the manual and door jamb sticker correctly, its 45/45 max load and 41/38 normal load.
Also, i assume id have to store the new settings if i lowered my pressure all around??
Old 05-05-2014, 06:29 PM
motorguy61's Avatar
I am running mine at factory callout 310kPA
Old 05-05-2014, 07:41 PM
GTS00021's Avatar
So full load conditions. Any particular reason for that as opposed to normal load?
Old 05-05-2014, 08:03 PM
Vic55's Avatar
I run 290 so whats that about 41 cold psi?
Old 05-05-2014, 08:07 PM
GTS00021's Avatar
I think that would be around 43 psi
Old 05-06-2014, 06:40 AM
60614allroad's Avatar
I'm running 41psi (21") that's what the manual recommends.
Old 05-06-2014, 08:24 AM
GTS00021's Avatar
I thought it was 41/38 for normal load on the 21s per the manual? i could be wrong. i'll check.
Old 05-06-2014, 11:22 AM
You are correct, and I just checked mine and they read 41/39.....
md4msu
Wheels & Tires Discussion
03-18-2019 05:48 AM
Brandonb
S4 (B8 Platform) Discussion
11
02-22-2011 10:50 AM
Force-1
Q7 MK 1 Discussion
10
10-26-2010 01:51 AM
acadia1
11-15-2008 08:14 AM
Soner-O
Audi A3 / S3 / RS 3
9
03-08-2006 03:21 PM
Quick Reply: Sidewall bubble/tire pressure on RS7
