S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
DIY: Hardwired Radar Detector Install
Old 11-20-2010, 04:19 PM
  #21
rkdiddy's Avatar
Thanks for the great write-up Tails. I got my V1 installed today. The Bone Folder was a great suggestion. Picked one up from Michaels and it made the install that much easier.
Cheers!
Old 01-09-2011, 04:52 PM
  #22
asm777's Avatar
Default ATO or ATM connector?
Great write-up! Planning to follow suit but have a question about which connector I need for the fuse box.
Can someone confirm that the "Mini" ATM one is the one I need? I read another DIY for the S5 showing the ATO connector and just wondering if Audi has a different fusebox or connectors on the S4s vs the S5s...
Links on Amazon:
ATM: http://www.amazon.com/Bussmann-BP-HH...dp/B000GKEXK2/
ATO: http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
Thanks in advance!
Originally Posted by Tails
To safely tap into the fuse box, get a Mini Add-A-Line accessory. This plugs in like a normal fuse, but provides a power lead. Tip: order this online, it was $24 at my local auto-parts store.
Originally Posted by bb vign
4. Using a TAPA Circuit (ATO, not mini), connect the lead to the end of your hard-wire connector:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install4Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install4Medium.jpg" border="0" alt="Photobucket"></a>
Old 03-20-2011, 05:37 AM
  #23
Kandiru's Avatar
Great writeup OP!
Getting my S4 in August, could this work?
http://www.blendmount.com/valentine.html
Old 03-20-2011, 05:47 AM
  #24
tofuking's Avatar
Originally Posted by Kandiru
Great writeup OP!
I looked into this as well, no it will not work unfortunately.
Old 03-20-2011, 03:11 PM
  #25
tofuking's Avatar
I just did this install a few hours ago. Successful install thanks to this write up. Thanks so much! What a great write up.
What i did different was i just electrical taped the ground that came with the V1 to the bolt, also i had to use a 2amp + 5 amp for the tap a fuse to get it to work. I used the 2nd fuse slot from the top on the column on the far left.
Now my V1 starts up when i start my engine.
Old 03-21-2011, 02:37 PM
  #26
Kandiru's Avatar
If you do like projects on cars, this tool kit is indispensable IMHO:
http://www.amazon.com/No-Scratch-Too...0746961&sr=1-1
And also a tab remover, looks like a flathead screwdriver with a forked end and an angle at the end.
Old 04-07-2011, 08:48 PM
  #27
jts4's Avatar
need some help,
1) should i get the hard-wire with or without the low-fuse?
2) do i need the blade fuse tap or the mini blade fuse tap to connect to the fuse?
http://cgi.ebay.com/VALENTINE-ONE-1-...item334aa37155
http://cgi.ebay.com/VALENTINE-ONE-V1...item5183adf78c
Old 04-13-2011, 09:02 PM
  #28
jts4's Avatar
^^^ help, anyone?
Old 04-13-2011, 09:36 PM
  #29
tofuking's Avatar
Originally Posted by jts4
^^^ help, anyone?
All you need is the hardwire cable that came with your V1 + a add a fuse like this one:
http://www.amazon.com/gp/product/B00...S1HZR54KA9MHFV
The V! hardwire kit has a clamp thing that will bite into the wire of the add a fuse to establish the connection. That should do it. That is how i did it at least.
Old 04-13-2011, 09:37 PM
  #30
tofuking's Avatar
You can buy that add a fuse at your local autozone. I had to put a 5 and 3 fuse in to get it to work.
Quick Reply: DIY: Hardwired Radar Detector Install
