DIY intercooler Misters/Sprayers! *PICS*
Like the idea of cooler intake temps even when your intercoolers are not doing anything at times like in slow traffic, or for cooling down after you just blew by all the traffic going oh around 100mph? Well here is a little intercooler kit I made up for my 2.7 using things i found at my local o'reilly auto parts store....
what you need:
1)universal coolant tank is what i used but your factory windshield washer tank will also work
2)windshield washer nozzle kit from dorman
3)windshield washer hosing
4)a "tee" connector
5)a windshield washer pump (I used my stock one, but if you would like to keep your windshield wipers get a second one)
what you need:
4)a "tee" connector
um...
what you need:
4)a "tee" connector
what you need:
4)a "tee" connector
hmm
oh and a few other things... if your either too worried or tired of lacking hp cuz stuck in traffic. Don't drive the car. If your stuck in traffic for a long period of time, well then you shouldn't be driving anyways. Learn to take side streets if need be. If "your" car is getting HOT... cuz your in traffic, there's something wrong. IC sprayers aren't the solution, nor using this system is even remotely a solution. It's a simple way to keep hp while your GOING 5MPH!!!!!! Uh does any one else here see the problem... hmm... I could care less if the IAT is raising cuz it's warm out and there's traffic. As soon as it clears, which usually isn't very long anyways, the car will normalize just fine on it's own. Hence this nifty little device called a.. a what.. a Radiator... Intercooler radiates heat once it picks up speed... Look at that.. Impressive huh. I know. I was BLOWN away by that awesome invention. lol, and those who apparently need INSTANT HP the moment traffic clears up a bit... Shouldn't drive their car if it's to hot for them to be happy.
Now that's just my .02 and my random venting. No direct comments or offense to anyone here, clearly.
And mind I say all this simply cuz I do know. My buddy who has had this car for the past five yrs, and of which I've been working on. Has never had an issue with lacking hp or at least enough to not be satisfied due to high IAT. Mind you, he's has all fans removed from the car and still was performing amazing well, even in traffic. Yes it got warm.. never hot, but safely warm. Sitting in traffic at 103 degree summers can raise temps no doubt. He never had any issues with lacking so much hp that he could ever notice. Don't ask why he had no fans on... there was a reason and I don't remember now. I think it may have been the fan controller, but not sure on that. Also he never had the clutch fan as it never came with the car when he bought it. Again don't ask why. lol
So hopefully no one gets offended by this randomness. I'm seriously looking forward to this yrs summer. Curious to see how the S4 will perform and react in these higher temps. I do know running the tune, the temps get alil warmer, but only when I'm on it fully. Normal driving and even gettin on it with short bursts, it still doesn't get above normal reading. So we'll see how summer turns out. That's is aside from gas prices... head they'll hit over 6 bucks this summer.... Won't be drivin the S4 much at all... if that in fact is the case.
To be quite honest, I wouldn't bother with either one of them. Two reasons... One, you get a bunch of **** on your windshield going on a decent trip, ya can't wipe it off cuz you haven't got the windshield wiper sprayers w/fluid anymore. Two, I'd rather have all motor and turbo, than to have to rely on water/meth to provide me the hp I want, and... only for a given amount of time before you run of water/meth mix.
Water/methanol injection is a cost effective way to add some decent HP. What "all motor and turbo" modification are you thinking of that is going to net 30-40 whp and maintain responsiveness while costing under $700. Driving style obviously impacts the rate at which the injected fluid is consumed. I can easily go a month without using up the washer fluid reservoir.
Your preference may be something else, but water injection is a good option for a lot of people.
true
Both systems can function alongside the windshield washer, so there isn't any loss of that functionality.
How do you like the tial 605's? That's what I have in mind. Little over 600 hp sounds about fun.
They were a very nice turbo setup. I had a stock engine and found them a little less responsive than I cared for, so I'm going with the FrankenTurbo's. The 605's without W/M injection take a big hit in the summer, much more so than K04's.
randerson
Audi Original "S" Cars
10-31-2004 03:24 PM
RASTA4
11
04-19-2003 05:46 PM
BukkakeRocky
02-28-2002 11:35 AM
pablo1
05-23-2000 07:55 AM
By Voices
09-21-1999 08:48 PM
