To the HB audience, MAF related
Old 03-20-2008, 01:19 PM
New Member
KramS4's Avatar
Default To the HB audience, MAF related
Does anybody knows how a RS4 MAF sensor transfer curve is related to the S4 bosch maf sensor?
I thought that a RS4 sensor on a S4 housing would result in a similar pattern, but the ECU couldn't even maintain idle. It is running far too lean.
Does anybody knows why?
With a 35% lesss cross section on the RS4 sensor it should bring the mixture to the rich side. The RS4 has a 35% higher scale, so I had though that It would, at least, work.
thx
Old 03-20-2008, 01:52 PM
AudiWorld Expert
nyet's Avatar
Default i did some prelim research on this but never finished it
give me some time, i might actually be able to get answers for you
Old 03-20-2008, 05:37 PM
New Member
KramS4's Avatar
Default OK, I will try next week also. I will ...
I will receive a new Bosch S4 MAf from overseas and try to tune my car. I just finished the running in of my rebuilt engine.
If you could find some answers its going to be great!
I use UNICHIP and they have a program to monitor the MAF behavior and than use the MAP/RPM to simulate the load signal to the ECU. If I could make the RS4 and S4 MAF to work, I will try to map their behavior. But its gonna take some time as I only play with the S4 once a month.
thx
DAP@EPL
07-01-2015 04:48 AM
poseidon5
10-26-2007 01:17 PM
oldyellar
02-23-2006 07:27 PM
LCP
12
03-10-2003 11:30 AM
ZKNY
10-14-2002 06:33 PM
Quick Reply: To the HB audience, MAF related
