Help...coolant issue?
#13
further update
after much time working on this issue i used a hose to flush out the rest of the crap and use the coolant temp sensor hole as a drain...i turned the car on for a min while letting the hose water run through....and it got clear...
put the sensor that popped off originally
then i added 3 liters of G12 then 3 Liters of water and now i have a weird noise coming from the engine and then when i turn the heat an added sound comes on only when i go to turn on the air...
its been a long day with this stuff so any last pointers on why this noise is happening
ps.
i added the g12 first then the water is that incorrect?
ps.
#15
so far so good
after letting it idle for a bit and taking it for a spin i guess i burped the s4 and seems to be running smooth..
thank all who have helped with this task and i have def learned much from this.
heads up for others
Audi s4 2.7 use 3 liters of g12 with 3 liters of distilled or deionized water..
this link also came in handy:
http://phjeer.us/~heathy/cooling.pdf
heads up for others
Albanach
A4 (B8 Platform) Discussion
09-18-2018 05:35 AM
OzzyLime
11
04-12-2011 06:08 PM
Luxus Panzer
11-14-2004 06:27 AM
