Solution for Fidanza S4 clutch rattling?
Old 08-02-2014, 08:31 AM
lear70's Avatar
Default Solution for Fidanza S4 clutch rattling?
Hello all, 2000.5 B5 S4 2.7T unmodified.
I recently had a Fidanza put on my car. Big mistake. Rattles REALLY badly when idling and the clutch isn't depressed.
I'm a little confused, as I would expect the same rattling regardless of clutch position (pedal engaged or not) if the engine RPM is the same. But at idle, it's VERY annoying, have to hold the clutch in all the time or it sounds like freaking rod knock. Yes, it's THAT loud.
Throwout bearing possibly bad (it's new)? I have a little rattling at low RPM when driving, but that's not a huge deal to me, it's the idling clutch disengaged that's most annoying.
And yes, I did a search, but no one really focused on noise in the difference in clutch positions and whether it's really the flywheel or something else and if there's a solution. Now would be the time, just tore my engine back apart, jumped timing on me less than 2k after the clutch job. I found a K04 Stage 3 engine (without clutch) I'm putting in, and I'm not sure if this will make the rattle better or worse and if there's a fix while I have it apart.
Thanks!
davemc87
Audi A3 / S3 / RS 3
06-13-2019 01:43 PM
Blewtoon
10-22-2005 04:15 PM
box_of_partS4
04-07-2005 08:34 PM
CoOlSlY
01-02-2004 12:34 PM
audi/s/scott
Performance and Tuning
30
12-12-2003 09:50 AM
Quick Reply: Solution for Fidanza S4 clutch rattling?
