Homebrew Stage III Experts needed for help: I have been fighting overboosting issues
Old 03-19-2008, 04:13 PM
  #11
PILL PUSHER's Avatar
The hole in my mbc is plugged~
Old 03-19-2008, 04:15 PM
  #12
Default I have tried 3 different N75 valves that I know work. I will double check my plumbing
but I am 99% sure it is correct. I have the diagram and went right off that. Whats up Carter, Psyched about the wheels!!!
Old 03-19-2008, 04:29 PM
  #13
AudiWorld Expert
nyet's Avatar
basically you shouldn't hear any air escaping
Old 03-19-2008, 05:04 PM
  #14
djillusion's Avatar
ditch the HB and get a custom tune.
Old 03-19-2008, 05:26 PM
  #15
Member
sj6sp's Avatar
Default Was it plugged when you ran MBC only?
I suspect (as others) you have a leak in the WG line.
Old 03-19-2008, 05:50 PM
  #16
Default no it wasn't plugged when running MBC only. I put epoxy on it last night,
plus I have a spare that has a check valve as well. I tried them both. What does plugging the hole do anyway?
Old 03-19-2008, 05:52 PM
  #17
Default I agree, but unfortunately I don't think that woudl fix my overboosting problem,
especially if I have a boost leak on a WG Line.
  #18
If I had a WG leak would I hear it from under the car if I did a pressure test?
Old 03-19-2008, 05:53 PM
  #19
AudiWorld Expert
nyet's Avatar
yes!
Old 03-19-2008, 06:02 PM
  #20
Default Awesome, I will put it on the rack tomorrow and let you know. 20psi enough for stage III pressure
test?
Quick Reply: Homebrew Stage III Experts needed for help: I have been fighting overboosting issues
