Here is what I get when I get when i try to use lemmiwinks with my APR chips
Old 09-05-2004, 08:54 AM
Member
Naptown::KckblAlstr's Avatar
Default Here is what I get when I get when i try to use lemmiwinks with my APR chips
<center><img src="http://pictureposter.audiworld.com/54689/lemminwinks.jpg"></center><p>I have a APR K04 beta ECU and an APR v5.0 (w/EMCS 2) ecu. The result is the same on both.
Old 09-05-2004, 09:08 AM
Former Vendor
ed@4induktion.com's Avatar
thats because Revo is giving you that one missing finger !
Old 09-05-2004, 09:15 AM
Member
Default Yeah...bastards! I had another idea that failed using the ProDiag
I thought, since its just adaptation channels which I can adjust with ProDiag, why don't i just look at lemmiwinks for the corresponding channel and then adjust the value accordingly. So I went the channel 1 to adjust rpms as a test. The prodiag gave me some information about what the RPMs were going to be after I adjusted them and sure enough turn the car on and it worked. So then I wanted to look at a different channel, say 8 or something. So when I get to that channel, I don't get any nice information about what the channel is or the value its at other than the number 128. So I try to adjust it to see what'll happen. It says the function isn't supported. So I guess that's out. Any ideas people?
Old 09-05-2004, 09:33 AM
Member
My2ndS4's Avatar
Default Are you trying to use a usb cable? Lemmiwinks doesn't support usb.
There was a post recently with the software you need for a usb to serial converter.
Elder Member
Audi2ptzero's Avatar
Default I dont see why the lemmiwinks wont work since its just changing values in the ecu
not in the chip itself. I mean it even works fine on my car with a custom GIAC chip which is not setup for me to use the GIAC mobile tuner.
Old 09-05-2004, 10:26 AM
BLK01S4's Avatar
Default Re: Here is what I get when I get when i try to use lemmiwinks with my APR chips
from a programming standpoint x55 is a general error could be a entire list of things .. I am willing to bet you are on a USB cable
Old 09-05-2004, 10:33 AM
Member
Nope...serial
Old 09-05-2004, 10:34 AM
Member
nope...serial. This is the one from the prodiag, but we have tried the vag-com serial also.
Old 09-05-2004, 10:53 AM
Audiworld Sponsor
DAP@EPL's Avatar
Default If you are using one of the "smart" VAG-COM cables (i.e., HEX-COM)...
You can't start Lemmiwinks after using VAG-COM because the cable will be in "smart" mode. You need to unplug it and then plug it back in so it reverts to "dumb" mode. But since you said you tried with multiple cables, I'd guess that this isn't your problem.
FWIW, I am able to connect to my APR v5.0 ECU with no problem. Not sure what is going on with your car.
-Dave Pramanik
Old 09-05-2004, 11:07 AM
Member
yeah...i don't understand at all. We've tried different cables and laptops.
Quick Reply: Here is what I get when I get when i try to use lemmiwinks with my APR chips
