Miss while at constant speed
#21
Doesn't say which pin to measure to though. If anyone else has this info, that'd be greatly appreciated.
Chris
oh ya, just ordered my new ICM's should be here monday.
Update: alright so I pulled off my never ending misfiring #6 coil and checked the spark plug "boot" connector and it measured 1956 ohms.. guess i gotta check them all. But this still doesn't explain why Im getting such high misfires. bentley mentions it could be, fuel injector, wiring harness at the coil, or at the fuel injector, also compression. I still wanna know how to check the actual coil itself. Bentley seems to not mention it at all, or i've missed several times.
#23
#24
haha I know that, I have been posting where the misfires are but no one has said anything about things that I could graph or voltages I could look at or symptoms of bad sensors or anything to the matter. That's more of what I am looking for, I can vag-com the car at anytime and post anything anyone would think would be helpful to diagnosing the problem.
#25
what do you guys think?
I gotta start swapping coils starting with 6 and see how it goes, then do the same with each injector. It's the only way I'll really know.
#26
I dont think mine is an injector problem unless number 2,4,5,6 are all clogged? Because I am getting misfires in all those.
How much would it cost to take it to the dealer for them to tell me whats wrong with it?
#27
If you got to a audi dealer They will charge you a fee of 1hour for diagnosis.depenging on how much they charge per hour over by me in NJ is $131 an hour but thats on the higher end i dont think there any dealer thats higher than that.
#28
There is a rotten egg smell when you give it gas. would that be consistent with a clogged cat, I do have an infrared thermometer.
The miss is all the time though, I did mess with the ICM's switch them around, reapply dielectric grease, and it seemed to help for about 10 miles or so and the it would miss again, but it only did that the first two times driving after messing with the ICM's.
If it took the dealership 3 minutes or 3 hours they would only charge me for one hour to tell me whats wrong with it?
#29
No normally they charge either a half hour or an hour for diagnosis to start with.If it gets involved you have to authorize additional time.You can always go and see if they will be able to try to diag it in a half hour.Maybe,maybe not.An hour seems to be the norm.Sometimes additional if its a involved or complicated problem and they have to troubleshoot extensive systems and components.
gregorydouglas89
A4 (B7 Platform) Discussion
20
11-04-2018 08:21 PM
Roswell
02-27-2009 12:52 PM
