P0305 Cylinder 5 Misfire....HELP!!!!
Old 03-21-2008, 06:19 AM
  #11
lemieux@curbside's Avatar
get a brass T from pepboys !
Old 03-21-2008, 09:25 AM
  #12
New Member
theboogieman1's Avatar
Default I switched the plugs and it moved to Cyl.2.
I'm guessing I need a new module?
Old 03-21-2008, 09:41 AM
  #13
Hyperformance's Avatar
A bad coolant temp sensor can cause misfires
Old 03-21-2008, 09:45 AM
  #14
New Member
Default already switched a little while back.
I'm pretty sure this is the upgrade from the black to the green one right?
Old 03-21-2008, 04:26 PM
  #15
New Member
Default FIXED!!!
for those who care, it ended up being a bad lower ignition control module. Got a new part and it fixed it up perfectly. As for the coolant warning, it ended up being a plug on the bottom that broke. Reconnected the wires and its all running great....for now. Thanks to all for the input.
Old 04-30-2016, 05:14 PM
  #16
Corey DeLasaux's Avatar
Originally Posted by theboogieman1
I just swapped the ignition control cables and the misfire moved to cylinder 2. Is the ignition module my problem? I don't want to fork out the money like I did with the coil pack and have it not fix the problem again.
These modules also require heatsink compound, very much like you would use on a CPU. If you have a vehicle with these modules, I would suggest especially if they are still functioning, to remove them from your airbox and giving them a fresh application of heatsink compound.
You obviously want to have the compound on hand prior to breaking free the bolts on the ignition modules even if you are just swapping them for troubleshooting.
Cheers!
DZA
09-08-2009 07:08 AM
audiphobic
03-28-2009 06:34 PM
audi2.7audi
15
10-13-2008 08:29 AM
shwndh
VAG-COM Discussion
01-31-2008 04:46 PM
ac921ol
10-29-2007 09:50 AM
Quick Reply: P0305 Cylinder 5 Misfire....HELP!!!!
