TQ clutch stuck off code
Old 05-10-2009, 03:16 PM
  #11
NiceS4's Avatar
I would definitely suggest getting the TQ replaced with the upgraded seal. This is exactly what happened to mine and I went on merrily clearing the codes until my tranny died (fluid leaked out into the chasis so I didn't know what was going wrong at the time). Went from a $1200 job to a $6000 job. Enough said?
If you're near NY I know a great shop for you.
Old 05-11-2009, 04:39 AM
  #12
New Member
tsumtingwong's Avatar
Originally Posted by rakta *chchchanges
Another thing to consider: there may be nothing wrong with your torque converter.
I had this code and it turned out to be the N94 solenoid inside the tranny valve body. N94 is the solenoid that actuates the lock-up clutch in the torque converter.
The solenoid is $150 or so, IIRC. And it can be accessed easily from beneath the car, it's just inside the ATF pan of the trans, along the rear of the valve body. You'll see six solenoids in a row; N94 is fourth from the left.
The only difficulty of installing this thing is you'll have to drain the ATF and refill it. This is NOT a fun exercise. And if you DO do this, make sure you DO IT RIGHT. Find the online documentation for the ZF transmission and make sure you follow the filling procedure to the letter.
Anyway, $150 and a couple hours of labor might save you a lot of money.
Hmm..now that is a very good idea - thank you for the heads up.
Old 05-11-2009, 06:08 AM
  #13
New Member
I have had the ATF fluid drained and new juice put in - took for freaking ever. Horrible procedure.
Old 05-11-2009, 06:38 AM
  #14
complacentsee's Avatar
Is that the procedure with the add fluid until it overflows, then wait for the overflow to stop and you have added enough?
LOL, these cars are PITA.
Old 05-11-2009, 06:53 AM
  #15
New Member
..while having VAG-COM plugged in to monitor the temp as the volume has to be absolutely precise, otherwise codes++
Old 05-11-2009, 07:03 AM
  #16
Ohh, that sounds more like it...
Old 05-11-2009, 08:36 AM
  #17
BTW, how much did that cost? I asked a dealer how much it would run and I was quoted something $1000-2000, but that was years ago. Obviously I never did it.
Old 05-11-2009, 10:27 AM
  #18
New Member
The tranny drain and refill with fluids and filter kit ran me $400.
seanwg
03-16-2018 09:07 PM
2004 allroad caledonia
2.7T V6 Discussion
04-07-2012 05:07 AM
Pchelka01
08-05-2011 02:58 PM
islingtonaudi
Audi 100 / A6 (C4 Platform)
05-28-2008 07:55 PM
BigMouse
01-03-2002 08:03 AM
Quick Reply: TQ clutch stuck off code
