Vacuum leak-- Brake Booster hose?
There's a hose at the back of the engine which goes into the firewall (between the battery and ECU) and it keeps popping off. It's got a couple curves in it and the side which connects to the engine looks like a snake's head-- angled head with two orange/red valves.
The connection isn't secure at all; I push it back into place but it doesn't lock and pops right off again. It's secured into place with painter's tape right now; very ghetto.
Anyone know what hose this is? Is it the brake booster hose? Is there a way to secure the connection? It seems like it would twist and lock into place but it doesn't work on mine. I get one side to connect but then the other pops off.
Yes, Brake Booster hose. put a clamp or tie wrap on it!
You should notice that braking takes a LOT MORE effort when that hose is off.
At least if were are talking about the same hose!
I've had the fortune of it not popping off while driving; it's occurred when the car is parked so I haven't really noticed a difference in braking.
I've looked in my engine compartment and I couldn't find a hose with these red valves...Is it in the same compartment with the battery and ecu (behind the firewall) or in the main engine compartment? Think you could post a pic?
You could get some of the small hose clamps at an autoparts store - that should take care of the issue permanently.
It's in the main engine bay but connects to the firewall. It's short (about 6 inches) and very thin (I'd guess .25" thick). I'm pretty sure it's the brake booster hose.
Yeah, now I'm thinking about clamps or zip ties to fix it.
ive noticed the same thing
When i went to go change the 02 sensor on the passenger side not to far from the egt sensor i had to remove the accordion tube intake looking thing and seemed to break the fitment of the hose to the tube from the brake booster vacuum hose
now the hose hangs loose ... air seems to be sucked in while i had the car on i ran my finger over it ...
do i have to get a new accordion tube thing or can i just tape it close on the tube thing and put a breather filter on the vacuum tube end of that. i have notice braking seems to be just a little softer but i figured it was from brakes wearing out..
any advice will help or info
CK NYoC
12v V6 Discussion
06-07-2005 10:55 AM
BSK auf Arbeit
Mid Atlantic Discussion
06-02-2005 01:27 PM
ssmolen
08-20-2003 04:05 PM
