S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
The DEFINITIVE Definitive Word on the Throttle Lag Issue(?)
Old 05-22-2015, 09:30 AM
  #151
allenst's Avatar
Default 2 cents
The engine management doesn't adapt to your style of driving instead it compensates for any engine wear or dirt build up etc etc
The idle problem occurs when the battery is changed because when the battery is disconnected the ecu forgets any unique settings it has in its memory for your engine wear etc
The build up of gunge in the throttle body means that the butterfly position changes over a period of time. The ecu knows this and compensates electronically.
When the ecu is wiped (when the battery is disconnected) it only knows its default settings so it thinks that the throttle butterfly is not fully closed and tries to close it by adjusting the stepper motor on the throttle . When it cant do this you get a viscous circle where the ecu is trying to shut off the throttle but the gunk under the throttle butterfly wont let it .....hence the hunting idle. This can be fixed by an Audi tech by resetting the throttle idle position in the ecu
clean and recode
Old 05-24-2015, 05:25 AM
  #152
gk1
gk1's Avatar
clean and recode
I'm not sure if this is the thread you meant to post in...but...no. Anything required to be stored would be in non-volatile memory. Your statement implies the odometer would reset to zero when disconnecting the battery...which we all know does not. Also one of the few benefits of FSI is the lack of gunk on the throttle butterfly. I've had 75k miles on mine and the throttle butterfly looked brand new on both sides. Only way to muck it up would be if you installed an over oiled aftermarket air filter.
Old 05-24-2015, 07:07 AM
  #153
MalibuCANE's Avatar
I finally found a place to fix my Lag problem on my 2014 S6. Carmax. It is disappointing that such a great car is plagued with this issue and more so that Audi wouldn't do anything to fix it on my 2014 model after many attempts. Overall I loved the car and will miss it but I couldn't stand the frustration and didn't want to be stuck with the car long term.
Old 05-25-2015, 05:03 AM
  #154
subterFUSE's Avatar
Get a replacement yet?
Old 05-25-2015, 12:43 PM
  #155
Nashtyboy's Avatar
I got this installed and it fixed it: TSB 2035235/2 - ECU update
Didn't do the TCM update.
If you're not sure if you still have the lag or not, the easiest way to reproduce it is to find a free-flowing right turn... slowing to normal right-turn speed and then hitting the accelerator created the most noticeable lag for me... on the order of a good second and a half before the engine woke up.
Old 05-25-2015, 01:37 PM
  #156
ben_aip's Avatar
What model year is yours if I may ask? Seems they're not doing any ECU updates for MY2014 and MY2015 S6/S7. saying it's not applicable. They've only done one that they said applies to my 2014 S7 - the TCM one. And if yours is a MY2014/15, what did you have to say to them just so that they'll update the ECM for you.
Old 05-26-2015, 05:42 PM
  #157
uttevrec's Avatar
Originally Posted by ke116ngc
Yes! I just got my car back today and they updated my ECU software to version 0007 and they updated the TCM software to version 0013.
How do you tell which version of software you have using VCDS? Is it at the end of the component field for the Engine and Transmission controllers? If so, I have the original software for both:
  • Engine: Component: 4.0l V8TFSI / H62 0006
  • Transmission: Component: 0B5 40TFSINAR H01 0009
Time for a dealer visit.
Old 05-26-2015, 08:49 PM
  #158
ke116ngc's Avatar
Correct. Your bold items are the version numbers.
Old 05-27-2015, 05:12 AM
  #159
subterFUSE's Avatar
Finally did an AutoScan after getting the updates, just to confirm I have them:
ECU
Previously on 0006
Now
Component: 4.0l V8TFSI / H62 0007
TCU
Previously 0009
Now
Component: 0B5 40TFSINAR H01 0013
Car does feel more responsive, but I still need to take it to a certain road where I know I could always get the lag previously. Then I'll be able to confirm or deny for certain.
Old 05-27-2015, 09:05 AM
  #160
ronbars's Avatar
Looking very forward to these updates at my 25k service. My ECU software is comparatively ancient:
Component: 4.0l V8TFSI / H62 0002
Quick Reply: The DEFINITIVE Definitive Word on the Throttle Lag Issue(?)
