Air suspension Q7
Air suspension Q7
Q7 4,2 TDI-2008
While driving the car lowered itself from comfort to dynamic, I wasnīt driving fast enough for it to do so properly.
The yellow warning light with a car and a downward arrow came on.
It doesnīt respond to any settings in the mmi even though the different modes arenīt grey.
It doesnīt respond to the buttons in the back for lowering it to loading mode.
Iīve checked for fault codes with vcds but there are none. The 5A and 15A fuse is ok.
Iīve had it Indoors in my garage over night but no difference.
Shortly before Iīve changed tires and had it in jacking mode.
The car is leveled so I donīt think itīs something wrong with the height sensors?
Iīm thinking if the relay has hanged up and thereafter burned the compressor?
Is there anyway to check the relay? Ohm measure it to see if itīs faulty maybe?
How can I check the compressor?
Big thanx in advance!
Greetings Johan.
Greetings Johan.
Ok, not the best forum in the world Iīm guessing..
I bypassed the relay and the compressor still didnīt work.
After taking it down I get why, the wires were damaged right were they go into the compressor.
rellascout
22
10-01-2020 01:58 PM
