Suspension Tuning Discussion Discussion forum for general topics regarding suspension tuning
Front air suspension stuck all the way up.
Old 06-25-2014, 10:10 AM
Dan Asbridge's Avatar
Default Front air suspension stuck all the way up.
I have a 2003 allroad, somehow the front two air shocks are stuck in the 4 setting and the back is stuck in 1. I was wondering if there is a bleeder valve for those so I can at least get it down and hopefully it will level out. Would I bleed it from the trunk compressor? Is there an auto level sensor that could be bad?
Dan
Old 11-26-2014, 08:25 PM
AudiA8NYC's Avatar
I'm not an expert at all, but if you have access to a VagCom, you should be able to calibrate the suspension quite easily. Good luck hope you find a solution.
Old 12-21-2014, 11:47 PM
Banned
tvsdprasad's Avatar
There may be several reasons for stucking with the suspension,this article may help you Troubleshooting car front suspension and wheel problems from noises or rumbling sounds
aclass
12-13-2017 11:46 PM
norwestie
Q7 MK 1 Discussion
12-14-2015 11:04 PM
crespo
08-21-2007 09:20 PM
|everso!|
06-15-2007 05:16 PM
Quick Reply: Front air suspension stuck all the way up.
